Holley Sniper Canister Vacuum Routing - JeepForum.com
post #1 of 5 Old 10-25-2021, 09:28 AM Thread Starter
claybuster84
1981 CJ5
Just installed a Sniper EFI on a 258 and need to know how to route the canister vacuum lines. Specifically the bowl line but could use the whole diagram if anyone can assist.
claybuster84 is offline
post #2 of 5 Old 10-26-2021, 02:52 PM
1984jeepjohn
Do you meen the little one over on the pass fender? I just installed the Sniper and am only using the one vacum line for the PCV valve on the valve cover. (I did the hyperspark distributor as well so no vacume needed there. More info or Pics?
If you meen the brake booster, it gose into the intake below the sniper
Was 84JeepJohn but was gone for a while.
1984jeepjohn is offline
post #3 of 5 Old 10-27-2021, 12:55 PM Thread Starter
claybuster84
1981 CJ5
No I have everything else hooked up I just need the line that went to the old carbeurator bowl vent. Where does it hook up to?
post #4 of 5 Old 10-28-2021, 05:50 AM
Rkuehljr
1983 CJ7
The Sniper doesn’t have a “bowl” to be vented/captured, so my memory is that I plugged mine. I can look this evening to confirm.
Sent from my iPad using Tapatalk
Rkuehljr is offline
post #5 of 5 Old 10-28-2021, 04:36 PM
Rkuehljr
1983 CJ7
I even used one of the caps that came on the sniper to plug the port on the evap canister
Sent from my iPhone using Tapatalk
Rkuehljr is offline
