HELP- is the tub and roll bar the same 4 a 78cj to 95? - JeepForum.com
post #1 of 3 Old 04-09-2009, 04:25 AM Thread Starter
Big_E
Guest
I want to buy a top kit called the safari windjammer. Maybe some of you have seen it, Its a half cab with a top, bed cover, and a cab backing. but cant find it for my 79cj7. there is one for 92-95 body style. Is it the same dimentions? Thanks for your input!
Big_E is offline
post #2 of 3 Old 04-09-2009, 05:46 AM
jerseyjeep2003
The roll bars are definately different, 92-95 have the family style roll bar. I believe the Safari top actually straps to the roll bar. Sorry, I don't think it will work for ya.
95 YJ 8" of lift 36" Iroks, & more mods than I can really afford. The General Lee....YEEEEHAA
href="http://s488.photobucket.com/albums/rr249/jerseyjeep2003/General%20Jeep/?action=view&current=trailride7-6-08105.jpg" target="_blank">http://s488.photobucket.com/albums/r...e7-6-08105.jpg
jerseyjeep2003 is offline
post #3 of 3 Old 04-09-2009, 08:32 AM
CrazyHorse6
1979 CJ7
The only difference between your CJ7 Sport roll bar and the Family style roll bar for the 92-95 YJ's are the way the rear bars come down to the rear mounts. The sport bar comes straight down from the loop to the mount while the family style runs back towards the rear for a short distance and then turns down to the mount. They still mount in exactly the same holes (except for two holes being 1/2" off), but the width and dimensions are generally the same. You will want a Bikini top vs a safari top as the safari top extends to cover the back seat slightly and uses part of the family style roll bar as a tie down. The bikini top just covers the main cabin. Bikini tops for the YJ jeeps will have velcro tabs on the sides to tie down to the horizontal bars that go from the loop to the windshield (which you dont have on a CJ) but you can just cut the velcro tabs off or swap the YJ bikini top for a CJ bikini top if you have the option as part of the kit. You'll need to look at it, but the windjammer should only tie down to the roll bar loop, and the CJ7 loop and the YJ loops are exactly the same, so you should be good to go there. Now the bed cover will be tricky because of the angle that the rear part of the roll bar comes down at - although they mount in the same location, the YJ roll bar comes down more vertically while the CJ roll bar comes down at more of an angle. Depending on how the bed cover wraps around the rear part of the roll bar, you might be able to get it to work. If all else fails, put in a YJ roll bar! Years 92-95, NOT 87-91 - those years still used the sport style.
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
What is the strongest clear coat you can roll on the roll bar over fresh paint? HHICJ7 Jeep CJ Forum 10 07-17-2018 09:42 PM
CJ5/CJ7 Roll bar. sgourd Jeep CJ Forum 9 04-10-2009 10:03 PM
Is this the right Roll bar for my CJ5? John Strenk Jeep CJ Forum 3 02-12-2009 07:11 AM
57 cj5 roll bar Luckyduck Jeep CJ Forum 6 03-11-2008 10:58 PM
78CJ Body Ratgunner Jeep CJ Forum 7 10-08-2006 08:44 PM
