Help Identifying this Rim - JeepForum.com
 2Likes
  • 1 Post By JoonHoss
post #1 of 11 Old 06-29-2020, 12:01 PM Thread Starter
garet.friedrich
garet.friedrich's Avatar
1979 CJ5
Folks, does anybody know where I can find a rim like this?
I had a set of 4 on a project 79 CJ5 i am doing for a guy and after powdercoating and mounting the tires it was discovered that one was bent beyond repair. I need 1, but would take 2 or even 4 if the price is right. Appreciate the help!
79 CJ5
garet.friedrich is offline
post #2 of 11 Old 06-29-2020, 01:32 PM
dirtdudeaz
1983 CJ7
Looks like a crager soft 8
dirtdudeaz is offline
post #3 of 11 Old 06-29-2020, 02:02 PM Thread Starter
garet.friedrich
1979 CJ5
Has 10 holes though. Is there a Crager version for that?
79 CJ5
post #4 of 11 Old 06-29-2020, 04:43 PM
WadeHiersSr
hmm... interesting dilemma you've found. I checked Black Rock and Pro Comp and they're all 8 hole as well. (the D-Window wheels get up to 10 holes... but the round hole ones max out at 8).
I'm interested to see what you find out.
WadeHiersSr is offline
post #5 of 11 Old 06-30-2020, 10:40 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Did you ask this question here before? I specifically remember looking for this exact type of wheel (10 hole) before for someone here.
They do make a 10 hole version, but it doesn't have the 'soft' edge like yours
https://www.speedwaymotors.com/Speed...-Inch,214.html
You say yours is bent; if you really want to keep it, a company like Stockton wheel or such should be able to fix it. Not a wheel shop, but a wheel repair shop
Hoss
garet.friedrich likes this.
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is online now
post #6 of 11 Old 06-30-2020, 02:56 PM
4Low2G0
4Low2G0's Avatar
Dynamic wheels soft and black maybe?
Whats over that next ridge?
4Low2G0 is offline
post #7 of 11 Old 07-01-2020, 07:22 AM Thread Starter
garet.friedrich
1979 CJ5
I found one on ebay! Thanks for the help everybody!
79 CJ5
post #8 of 11 Old 07-01-2020, 09:40 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Quick question; how wide are your current wheels; and how wide is the eBay one?
Further research definitely looks like the 10 hole wheel is what Sammi's had, I also thought they were pretty narrow (like 5-6"?)
Hoss
post #9 of 11 Old 07-01-2020, 02:20 PM Thread Starter
garet.friedrich
1979 CJ5
They do seem pretty narrow but not 5-6". I mounted 31x10.5x15s on them without issue.
79 CJ5
post #10 of 11 Old 07-01-2020, 02:37 PM Thread Starter
garet.friedrich
1979 CJ5
I have quickly gone through and educated myself haha. You are absolutely right Joonhoss they are 5.5" wide which is also the width of the ebay rim. I apparently had the shop mount the 31x10.5R15 tires on them without thinking if that might be an issue. After some research i see that it is doable....probably frowned upon....but doable.
79 CJ5
post #11 of 11 Old 07-01-2020, 03:18 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
No worries, just wanted to make sure you are getting what you needed.
Being that they are all that size, you may want to do a chalk test to figure out the right inflation on them, because in all likelihood they will possibly crown a bit and wear out the centers at 'standard' psi.
Hoss
