Help!! I need a locking hub replacement part - JeepForum.com
 1Likes
  • 1 Post By jeepdaddy2000
post #1 of 9 Old 08-24-2019, 11:00 AM Thread Starter
vhosie
vhosie's Avatar
Hi! Hopefully someone can help me here! I need to find a replacement part for my locking hub. I opened up my Dana 30 differential and a plastic seal it has inside was all broken. I need to replace it but haven't had any success on finding a spare. Have looked EVERYWHERE!! Morris 4x4, Quadratec etc... And I'm desperate, can someone help me?? It's this part.
20190824_102354_1566662287901.jpg   20190823_121041_1566662334787.jpg   20190823_104417_1566662379391.jpg
vhosie is offline
post #2 of 9 Old 09-11-2019, 11:05 AM
thord
Mine did the same so I ordered completely new hubs. I've never seen parts for them, but I wouldn't want more plastic anyway.
thord is offline
post #3 of 9 Old 09-11-2019, 03:07 PM
DougE
1983 CJ7
PM me your address and I'll send you my old ones that I replaced. Not 100% complete but sure what you're looking for is there. Just postage.
1983 CJ7, 258I6, T4, Dana 300, 31x10.5x15 DuraTrac
DougE is offline
post #4 of 9 Old 09-12-2019, 03:25 PM
RedNeckCorvette
1979 CJ7
Look closely at the seal, if it has a number any good hydraulic or bearing shop should have them.
Might find it on line also.
RN
RedNeckCorvette is offline
post #5 of 9 Old 09-19-2019, 07:58 AM Thread Starter
vhosie
vhosie's Avatar
Thanks for the answer!! What did you do then? I agree that it would be a lot better to not use plastic. Where did you buy your new hubs?
vhosie is offline
post #6 of 9 Old 09-19-2019, 07:59 AM Thread Starter
vhosie
vhosie's Avatar
You're too kind, thank you! If you're not using them any more, what are you doing now? What was your solution for not using them. I live in Colombia, South America... it's a bit far away
vhosie is offline
post #7 of 9 Old 09-19-2019, 08:00 AM Thread Starter
vhosie
vhosie's Avatar
RN
Unfortunately it doesn't... but if there is an alternative to not using plastic seals I think it would be much better
vhosie is offline
post #8 of 9 Old 09-19-2019, 08:35 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
No offense, but I think you're beating a dead horse here. I think fixing a set of 50 year old marginal hubs is a study in frustration at best. Unless you're looking to restore the rig there are a couple of better options.
Many upgrade to 6 bolt hubs. Most expensive scenario but a good decision for those looking to do heavy duty work with their rig.
Best case 5 bolt scenario is to upgrade to a set of Warn premium hubs. These are the most expensive, but are common, proven, and Warn provides many replacement parts.
Other option is to spring for a new set of cheaper hubs, such as Mile Marker or Rugged Ridge. If you're not doing a lot of heavy wheeling these may be a better option as their cost is half that of Warn.
RedNeckCorvette likes this.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #9 of 9 Old 09-19-2019, 09:19 AM
DougE
1983 CJ7
vhosie - when I disassembled the hubs to replace the rotors I realized that the parts from the two sides were not identical. Probably due to a number of maintenance cycles and a variety of mechanics. So rather than deal with the unknown I just replaced them with Mileage Marker hubs. I didn't realize you were in South America, but still willing to ship. The package for both weighs about 3.2 Lbs (1.5 Kg?).
DougE is offline
