Help with Accelerator pump springs - JeepForum.com
 1Likes
  • 1 Post By Hoover7
post #1 of 3 Old 09-16-2019, 06:32 PM Thread Starter
1970pelle
Hello. I have screwed up again. After having my Weber 38 torn apart for who knows how long. Everything is back together just fine, except the two accelerator pump springs. The weber 38 I have has two pumps one is mechanical the other is vacuum operated. The springs used are two different sizes, but they fit both pump diaphragms. So could someone tell me where the small spring goes then the large, which would be easy after finding out the first.
A thousand Thank you's Ken(I forgot)A.
A nation that cannot control its borders is not a nation.?
― Ronald Reagan
1970pelle is offline
post #2 of 3 Old 09-16-2019, 07:07 PM Thread Starter
1970pelle
I think I may have found the answer. Check me, the large spring goes to the Vacuum pump and to the outside of the diaphragm. The smaller of the two goes to the mechanical pump. The spring faces into the carb body.
Ken
― Ronald Reagan
post #3 of 3 Old 09-16-2019, 07:41 PM
Hoover7
Hoover7's Avatar
I'm pretty sure seeing a couple pictures of the springs would be helpful, at least for me. I've got a Weber 38 in a box at the shop, but would be tomorrow before I could confirm anything for you.
Hoover
pedal2themetai likes this.
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
