HEI new gear or Replace with Old gear - JeepForum.com
 4Likes
  • 1 Post By CSP
  • 1 Post By JeepinGeo
  • 1 Post By Renegade82
  • 1 Post By BagusJeep
post #1 of 5 Old 05-09-2021, 01:14 AM Thread Starter
Speedybon
Speedybon's Avatar
1968 CJ5
I just installed a new HEI distributor with the new drive gear. I was reading in another jeep forum, and they recommend installing the old gear because the new one wears. Also, instead of 5 degrees, what about 7 to 8? I guess if I get pre-ignition at full throttle, back it off. It's spotless inside. It only has 37000 miles on it.
Speedybon is offline
post #2 of 5 Old 05-09-2021, 08:19 AM
CSP
The new ones can be hardened and chew up the other gear. It seems to be more prevalant on V8s.
I like to advance timing to the point of detonation and back off two degrees. Using a specific number isn't always applicable. At the altitude I live at we can need 10-12 degrees of initial advance.
Axhammer likes this.
CSP is offline
post #3 of 5 Old 05-09-2021, 09:01 AM
JeepinGeo
JeepinGeo's Avatar
I bought a cheaper HEI unit from CRT performance for my 258 and I installed it with the gear that was already on it. No issues thus far. At some point many years ago, these HEI kits were sent out with hardened drive gears for "strength" but they ultimately proved to be money wasted as they tore up the softer cam gear. I don't believe it's an issue in modern day so I would install it as is. As far as timing, every engine will be slighlty different, i.e. altitude and engine modifcations. At my altitude here in central Florida, my timing is set at 8 BTDC and it runs smooth.
JeepinGeo is offline
post #4 of 5 Old 05-09-2021, 09:01 AM
Renegade82
Renegade82's Avatar
1982 CJ7
I've always read that the gear issue was a v8 issue and have yet to read about any problems on an inline 6. I admit I have zero experience on the issue with multiple engines, but I put one in my wifes 258 2 years ago and one in my 258 a year ago and have seen no issues to this point. However I haven't pulled either to actually look at them.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #5 of 5 Old 05-10-2021, 03:57 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
If in doubt try to drill the gear. If you can, it is fine for material hardness.
The timing marks and manual can be a bit misleading. You are dealing with modern fuels, worn timing chains, worn distributors and possibly harmonic balancers that have moved.
There are three methods I have used, the set by timing light and marks as per manual, the manifold vacuum method and the pinging method. The last two are particularly useful on my 1951 L134 as I cannot see the timing marks on the flywheel that well as it is under the starter. My guru when i was a kid was an older guy with 20 years of working on performance cars (Jags, Alfas, Astons, Ferraris) and the pinging method was his favorite.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
