HEI Distributor / CRT - JeepForum.com
 3Likes
  • 2 Post By uptillnow
  • 1 Post By ShopJock
post #1 of 15 Old 06-29-2020, 03:06 PM Thread Starter
ccoyle71
Before I pull the trigger on this HEI distributor, I wanted to confirm with you guys.
https://crtperformance.com/shop/ols/...-232258-42l-i6
I'm on a budget unfortuately, and a DUI is a little out of reach for me with my other upgrades in process. Have any of you guys had good / bad luck with this distributor or CRT as a company??
Thanks!
ccoyle71 is offline
post #2 of 15 Old 06-29-2020, 04:49 PM
WadeHiersSr
That looks like exactly the same Disti that I bought for mine... branded differently. (mine was Top Street Performance branding). Pretty sure they're all made in China and rebadged for whoever is selling it. I haven't gotten to the point of starting mine up yet... but I can say that the machining is spot on and it dropped right in.
I'm about 3-4 weeks out from my first startup... so if you're up for waiting, I can give you a better review on it then.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
WadeHiersSr is offline
post #3 of 15 Old 06-29-2020, 05:38 PM
uptillnow
uptillnow's Avatar
Chris,
Many use and have used the CRT H.E.I. distributor for their 6 cyl Jeep. It will give you 4-5 times more spark energy than the Duraspark ignition you have. It also has 20-22 degrees total timing. That is allot more than your emissions advance in your Motorcraft distributor. This will allow you to burn pretty much anything you throw at it, Rich-Lean etc.
Do not get the black cap. The black is made with carbon for color and will carbon track/flash over easier.
I have heard of only a couple people with 6 cyl gear issues, and that was easily 10+ years ago. After reading many many posts about it, I have concluded the 6 cyl gear issues were generally mixed up with the V8 gear issues where O.E. AMC had 3 different harnesses' on the cam gear adding to the need for "matched sets".
I like the "Performance" H.E.I.'s. DUI seems to be the only one left in the market. The cost for all of their advantages is more, and they perform and last a long time.
You will be happy with the CRT.
UTN
uptillnow is offline
post #4 of 15 Old 06-29-2020, 08:14 PM
seth13_1984
1977 CJ5
I installed a CRT in my 258 a couple years ago. Do it and never look back.
Sent from my iPhone using Tapatalk
'77 CJ5 in SE Ohio
258 Straight 6
Carter YF Carb
Montani Semper Liberi
seth13_1984 is offline
post #5 of 15 Old 06-30-2020, 04:56 AM Thread Starter
ccoyle71
Thx guys - will order today
Sent from my iPad using Tapatalk
ccoyle71 is offline
post #6 of 15 Old 06-30-2020, 09:12 AM Thread Starter
ccoyle71
One more question - will i run the same type plugs with this distributor or something different??
I've been using the Autolite 985s. Thanks!
ccoyle71 is offline
post #7 of 15 Old 06-30-2020, 10:30 AM
seth13_1984
1977 CJ5
I think I ran the same plugs but had to regap them. Canít remember with 100% certainty though.
'77 CJ5 in SE Ohio
258 Straight 6
Carter YF Carb
post #8 of 15 Old 06-30-2020, 11:13 AM
uptillnow
uptillnow's Avatar
These engines seem to work best with COPPER spark plugs.
My personal preference is:
1. Champion RFN14LY (82)
2. Autolite 985
3. NGK ZFR5N (3459)
With the HEI, I never gap the plugs over 0.045" maximum. This works great and last's a long time.
UTN
Shawn Watson and Willtek2720 like this.
post #9 of 15 Old 06-30-2020, 12:21 PM Thread Starter
ccoyle71
Thx - super helpful!
ccoyle71 is offline
post #10 of 15 Old 07-01-2020, 09:44 AM
hp_lovecraft
1981 CJ5
New plug wires designed for the higher voltage is recommended. I think I asked for a "1980 F150 with I6" for the wires, since they would be close in size. The Chevy 250 is also a popular choice, but the distro sits towards the front, so the wires dont match up right for the AMC 258.
Other then that, you have to think about if you are going to use a relay, and if you need the tach hooked up. After that, it really is the best upgrade I've done to my CJ. Completely cleaned out the engine compartment, and runs super reliably. Parts can be found at every parts store, though I've never needed any
hp_lovecraft is offline
post #11 of 15 Old 07-01-2020, 10:44 AM Thread Starter
ccoyle71
The distributor I ordered comes with 8mm wires - I was planning on using those - I hope that's correct. And my understanding is the "best" way to install the HEI is with a relay / fusable link. I think I understand that concept. I have read through the documentation.....and it seems to make sense.....but I'm hoping I can pick up what I need at local parts stores. I don't think a relay will come with the distributor from CRT - just the Distributor and wires. Can I go buy a 30/40 amp relay and fusable link from a local parts store? Is that what you guys recommend?
I'm hoping it delivers next week - and I'm sure I'll have questions when it does. Thanks for all the advice, I love this forum.
ccoyle71 is offline
post #12 of 15 Old 07-01-2020, 11:14 AM
uptillnow
uptillnow's Avatar
The 8mm wires that CRT provides are the "Packard" wires and are adequate. Of course the 8.5mm wires will contain the spark energy better, but if you keep the spark plug gap at or below 0.045" you won't have that spark energy build up looking for any ground to jump to.
I use the Beuler BU5083 relay & get a pigtail. https://www.qualitymobilevideo.com/5083.html
I buy 10 at a time and have some on hand for those special problems.
Since you are using a relay, you will find you will have "engine run-on", this is from a slight alternator feed back that will keep the relay engaged. You will need a diode "1N4002" industry number that can be interchanged into most other part numbers. I usually have 10 on hand but recommend buying a couple 2.
Good Luck
UTN
post #13 of 15 Old 07-01-2020, 12:52 PM
hp_lovecraft
1981 CJ5
It will run, and probably run just fine without one. The HEI just needs a 12v source to run. On 1980 and later CJs, they have a ballast resistor that lowers voltage to the ignition.
So you can wire the old coil wire directly to the HEI. Won't hurt it. Might run great. Or you can run to a relay, that also has a 12v from the battery (or solenoid). That way, the old coil wire just turns the relay on and off.
Yes, every car parts place will carry relays. I think I bought mine at walmart.
post #14 of 15 Old 07-01-2020, 11:14 PM
ShopJock
1980 CJ5
last year I installed a CRT H.E.I. with the 8mm from them also. Came with excellent instructions. I kept it simple - no relay. When you take out the old Duraspark control module, there will be running to it from the firewall, a 12G red wire which supplies 12volts (its the only large red wire there). Cut it at the Duraspark module, splice more 12G red wire onto it to reach the H.E.I. This replaces the old coil wire which you can remove and eliminates any resistors. For neatness, I purchased a distributor pigtail. Regap the plugs, retime the engine 10-12 BTDC. The system works great. I spent most of my time pulling out old wires, stuffing the new power wire into the loom, and making things look neat.
Shawn Watson likes this.
I only need the tools that I can't find.
ShopJock is offline
post #15 of 15 Old 07-02-2020, 06:31 AM
Shawn Watson
Shawn Watson's Avatar
1983 CJ7
^^^Indeed^^^ Easy peasy.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
Shawn Watson is online now
