Heater cable options? - JeepForum.com
 2Likes
  • 1 Post By ranger83
  • 1 Post By BrutusBlue
post #1 of 15 Old 04-16-2019, 09:11 PM Thread Starter
Cutlass327
Cutlass327's Avatar
1978 CJ5
Driving the other day was a beautiful warm day, so I opened the vents. Come to find out the next morning when it was mid 30s, the vents were not closed although the cable was pushed in to the "heat" position. Looking under the dash, I find that the air control cable is now bend around the linkage post in an extra loose lap. I have already replaced these Crown/Omix crap pieces twice now, either I got tired of the knobs pulling off, the cables bending, etc.
I have been looking for options. Finding these, at almost $100 a set, I wonder if they're worth it. I figure I have already spent that replacing junk with junk, so if they are better, I will be better off...
https://www.cjjeepparts.com/control-...-5463657k.html
Has anyone ever tried them? Any reviews? Any other options???
Rick
Cutlass327 is offline
post #2 of 15 Old 04-16-2019, 10:54 PM
LKCJ
LKCJ's Avatar
1983 CJ7
Hey Rick,
Not sure if you have checked out the set MTS has or not. I was on there sight a few weeks back and I think they carry the hole set. Don't remember the cost though.
https://www.mtscompany.com/jeep.htm
Sent from my SAMSUNG-SM-N920A using Tapatalk
Lance
1983 CJ7
Sherwood Green Metallic/Nutmeg Interior
4.0 I6
T-5/Dana 300
Dana 30/Model 20 with 4.10 gears
33/12.50/15 BFG's
LKCJ is offline
post #3 of 15 Old 04-17-2019, 07:28 AM
BrutusBlue
1982 CJ7
eBay seller under the name barneysjeepparts sells the kit that includes all 5 cables. I think MTS makes them for him. Pricey but very well made and worth every penny in my opinion. I was one of his first customers when the 78-86 full kits came out. I have thought about labeling the center of the knob with some sort of symbol or letter for each function. The only minor issue is the metal collars fade a bit over time.
11B14EB1-DFF2-41BC-B090-9862C54AAD93_1555507535476.jpg   E58B5A16-4B00-4E81-8144-7B7A394F993E_1555507654665.jpg
BrutusBlue is offline
post #4 of 15 Old 04-17-2019, 12:40 PM
uptillnow
uptillnow's Avatar
Rick,
I have come across the same problem you are experiencing. I have found on mine, the inner cable are twisted strands that makeup the inner cable. When these are pushed and pulled for a while, they expand the twisted strands "frays" it so eventually the cable won't open or close all the way. This happens with manual choke cables as well.
I have found a "Morse" cable is solid, therefore ideal for the push/pull. What ever you get, check out the inner cable for twisted strands or solid wire.
https://www.cccables.com/ this is information
UTN
uptillnow is offline
post #5 of 15 Old 04-17-2019, 02:58 PM
walkerhoundvm
walkerhoundvm's Avatar
1981 CJ8
I think they put little stickers in these now, to look more like OEM. I'm tempted, but the first thing I've done is to make sure all of the mechanisms are as free-working as possible. Not much effort for the cables if everything works as smoothly as it should from the factory.
Could you polish the metal collars? Sure beats the painted plastic ones from Omix, where the paint falls off after a few months.
walkerhoundvm is offline
post #6 of 15 Old 04-17-2019, 05:30 PM
ranger83
UTN,
Did you get a set of these and do you like them? I will have to replace mine after summer is over.
Mark
uptillnow likes this.
Ranger83
86 CJ7(current)
83CJ5(former)
ranger83 is offline
post #7 of 15 Old 04-18-2019, 01:35 PM
jp360cj
1977 CJ7
I'm not sure who makes them, but www.vintagejeepparts.com carries some cables that aren't made by Crown or Omix. Haven't used any, but it's the only place I've found with the specific 76/77 cables.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #8 of 15 Old 04-18-2019, 02:36 PM
ranger83
not sure about the heavy duty control cable but the three piece set is Omix according to their website.
Ranger83
86 CJ7(current)
83CJ5(former)
ranger83 is offline
post #9 of 15 Old 04-18-2019, 10:41 PM
BrutusBlue
1982 CJ7
I have considered getting a dremel brush after them and I have thought about painting them...just been too lazy to pull them off.
post #10 of 15 Old 04-19-2019, 08:09 PM Thread Starter
Cutlass327
Cutlass327's Avatar
1978 CJ5
Wow, thanks guys.
These cables are solid wire the whole way thru as far as I can tell. I do lube the mechanisms and such yearly, usually after that bent cable reminds me. The vent one is ALWAYS stiff though, even after a good lube of white lithium and working it "loose". I always feel like I am going to pull the cable out of the dash opening the vent. I'm thinking that barrel adjusted cable is done in...
The 3pc set on the Vintage Jeep Parts site are the junk style I'm replacing. They sell the MTS individually there though, INCLUDING the 2 oddball hard to find ones.
I looked on MTS page, and I couldn't find pricing.
I did happen to find this page while looking around some more. It is interesting how Google on the mobile shows some results, but then Google on the laptop shows others...
The set of 3 for $95.98. I am very tempted to go this route, but asking them if they can get the one with the barrel adjuster too, as that one is the original, and I am wondering what kind of shape it is in internally after 41 years. I also like that they are using a nut, not those locking tabs that never hold. I have to put a huge ziptie around the defrost one to hold those tabs out, and then the bezel is never flush to the dash.
Rick
post #11 of 15 Old 04-21-2019, 10:20 AM
BrutusBlue
1982 CJ7
Good call Walkerhound..here are some new ones I ordered after you said that
51551CDF-3C22-4E6C-8F68-2202E8441DF4_1555863511913.jpg   A78A370E-804C-43C7-8C5F-F80A8F483B42_1555863574819.jpg   BC7CB589-3975-40B8-A110-4E43626F258C_1555863592225.jpg
Cutlass327 likes this.
post #12 of 15 Old 04-21-2019, 07:58 PM Thread Starter
Cutlass327
Cutlass327's Avatar
1978 CJ5
Did they all come in a kit of 5, or did you have to order them separate? That is exactly what I am looking to get.
Rick
post #13 of 15 Old 04-21-2019, 08:58 PM
76SmurfadelicCJ
76SmurfadelicCJ's Avatar
1976 CJ7
Cutlas327- i have a set of these brand new in the package still i am trying to sell if interested. i am in Texas
76SmurfadelicCJ is offline
post #14 of 15 Old 04-22-2019, 10:15 AM
BrutusBlue
1982 CJ7
My order came with all 5.
post #15 of 15 Old 04-22-2019, 02:37 PM Thread Starter
Cutlass327
Cutlass327's Avatar
1978 CJ5
PM sent
Rick
CJ Heater Box Restoration...pic heavy!! rixcj Jeep CJ Forum 436 04-12-2019 04:56 PM
Heater cable repair JohnnyRotten Jeep CJ Forum 7 03-24-2019 04:44 AM
98 Jeep XJ Heater a/c control cable DHC45 XJ Cherokee Technical Forum 6 11-08-2018 09:32 AM
Heater Cable needed Warriors48 TJ Wrangler Technical Forum 10 10-31-2018 05:22 PM
1990 yj door jamb switches and a fix for heater cable mikwallace YJ Wrangler Technical Forum 4 02-25-2018 09:34 AM
