Has any one used this jack base with a cj - JeepForum.com
 17Likes
post #1 of 70 Old 07-28-2021, 03:35 AM Thread Starter
agear
http://www.quadratec.com/products/92...iABEgLT9_D_BwE
Anyone use this jack base with a cj ?.
I have 33s with a 2.5 suspension lift if it matters
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 70 Old 07-28-2021, 04:58 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
A 2x4 and a handful of nails will cost under $5.
I carry a farm jack, and a wood block made from a 2x4.
Wyo likes this.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #3 of 70 Old 07-28-2021, 05:47 AM
jay-h
I'd suggest replacing* the stock jack. With large tires, on the trail, the little screw jack really could be unstable.
Maybe something like this. I worked one like this (not my rig) on the trail and it was pretty good. There are a number of different brands and configurations to choose from.
https://www.newegg.com/powerbuilt-64...0YP-002R-00002
* Added: Carry the scissor jack, sometimes you might want a second point of contact for stability. But don't use it as your main jack.
Wyo likes this.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #4 of 70 Old 07-28-2021, 06:03 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Does anyone actually use the factory scissor jack?
Matt
Matt1981CJ7 is offline
post #5 of 70 Old 07-28-2021, 07:38 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I'd be a little leary of using that but sometimes you just got to McGiver something together.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #6 of 70 Old 07-28-2021, 08:59 AM
Wyo
Wyo's Avatar
Ummm just no, no way is that worth 60.00, too many things can be just found or picked up as an alt.
Wyo is offline
post #7 of 70 Old 07-28-2021, 09:16 AM
Delta0
Delta0 is offline
post #8 of 70 Old 07-28-2021, 09:38 AM
Delta0
Delta0 is offline
post #9 of 70 Old 07-28-2021, 09:42 AM
Wyo
Wyo's Avatar
Originally Posted by Delta0 View Post
Man that looks like the hot tip for snow!!!!!!!!!!!
Some Chinese stole the vid to sell on her amazon page though.........
generic amazon link for 112.00
https://www.amazon.com/Flieeya-Exhau...omotive&sr=1-2
still giving money to the Chinese though.
Wyo is offline
post #10 of 70 Old 07-28-2021, 11:13 AM
jay-h
Wow. I haven't seen those in years. the old JC Whitney catalog used to have something like that back in the 70s
I just saw something similar with a hand pump in Home Depot targeted at contractors.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #11 of 70 Old 07-28-2021, 11:38 AM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Jack base?
I keep about an 8 inch bottle jack and a scissor jack (about like yours) in my "5"
I have maybe 5 more at the house, one of them is a favorite, a scissor with a knurled pad on top, the pad is about 4" X 6", It's wonderful to use where you might need a wide pillar under something that otherwise might slip off a traditional jack.
As unsafe as people make it sound, I also use 2 x 4 blocks, bricks, and cinder blocks to gain height (if need be).
This $60 contraption looks to be a "Fad" item to me!
Looks neat, but we can improve on it!
I could make something (almost for free) in just a few minutes time, that would surely have the same usage.
Run down to the Salvation Army (or other) and pick out a heavy cooking pot with your desired depth, roll it face down, and set your jack on it.
Drill some 3/8 holes, Maybe some 3/8 grade 8 bolts to anchor it together.
------JEEPFELLER
JEEPFELLER is online now
post #12 of 70 Old 07-28-2021, 11:59 AM
Delta0
An exhaust air bag jack looks a handy tool to lift your car on your drive.
At 9lbs weight, it's got to be lighter than any other safe jack.
However, I have to admit that I've never used one.
Delta0 is offline
post #13 of 70 Old 07-28-2021, 01:41 PM Thread Starter
agear
To be honest I was looking for an alternative to my high lift jack . I can jack up my jeep from the front bumper, rear bumper or either side rock slider. They are all strong enough. But with the high lift it'll lift the whole dang jeep up and the handle is dangerous if you don't know how to use it.
agear is offline
post #14 of 70 Old 07-28-2021, 02:45 PM
Axhammer
Axhammer's Avatar
Why not use some scrap wood? That’s all I have ever used.
I have a milk crate with a 12”x12”x 3/4” plywood for soft terrain, a scrape piece of 4x4, and a couple or three, 2x4 pieces to help when needed. I also have a small floor Jack & a four way tire iron, to go with it. It’s all in the back of my truck…lol
I am totally unprepared for a flat in my CJ-7. I removed the OEM scissor jack when I did my engine swap. I never had the OEM tire iron. I do have the OEM spare on the spare tire carrier. The only thing I have in the back of my Jeep is a 1” braided line for an emergency tow strap. My plan is to call USAA if I get a flat between home and work, or anywhere in between, until fall when I put the hardtop and steel doors back on for the winter.
I guess I’ll put together a few pieces of wood, a bottle Jack and a four way tire iron, along with my 1” emergency tow line, and throw it in a milk crate in the back of my Jeep.
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #15 of 70 Old 07-28-2021, 03:11 PM
jay-h
I've used my bottle jack on the trail several times (mostly to help others, until earlier this year when I ripped my own tire). There cheap, small, throw a few 6x6 pieces into the mix and you're set.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
