Harmonic Balancer wont come off - JeepForum.com
 10Likes
post #1 of 27 Old 08-29-2019, 01:17 PM Thread Starter
calebsoldcj7
Just bought an AMC 304 and am currently in the process of replacing the cam and the timing chain/sprockets. The harmonic balancer is stuck and not budging. I have the chicken foot tool, using only two sides because it is a 4 bolt balancer, and even with an impact it has not moved. I put the crank bolt back in and pushed off of that with the tool, thinking that i might be pushing off of the balancer itself. with a breaker bar it is just spinning, and eventually it just bends my puller tool.
Any thoughts?
calebsoldcj7 is offline
post #2 of 27 Old 08-29-2019, 01:58 PM
jjgrow
Here's a couple of things that might be helpful:
https://www.jalopyjournal.com/forum/...er-sbc.509163/
- Jeff
1986 CJ-7
jjgrow is offline
post #3 of 27 Old 08-29-2019, 02:12 PM
80cj
80cj's Avatar
1980 CJ5
Try shooting some penetrating oil in the balancer bore. PB Blaster seems to work well for me.
80cj is offline
post #4 of 27 Old 08-29-2019, 03:51 PM
Fourtrail
1974 CJ6
kroil penetrant, leave the bolt started in so it doesn't jump off onto the floor and snug the puller up good and go inside and have a few beverages. When you come back in an hour, likely that it had popped off. Just give it time and don't rush it. Always try to push against the bolt so you don't mess up the threads in the crank. Also, you did get the washer off after you pulled the bolt out? That can sometimes hang you up if you aren't pushing against the bolt head.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #5 of 27 Old 08-29-2019, 05:50 PM
80cj
80cj's Avatar
1980 CJ5
That would be a good reason for it not to come off even if you dumped a gallon of penetrating oil on it.
80cj is offline
post #6 of 27 Old 08-29-2019, 09:18 PM Thread Starter
calebsoldcj7
Just shot some in, going to let it soak in tonight
post #7 of 27 Old 08-29-2019, 09:19 PM Thread Starter
calebsoldcj7
Yes, i actually went back in thinking i forgot the washer, but its out. Leaving it tightened with pb blaster tonight will update tomorrow morning.
post #8 of 27 Old 08-29-2019, 09:22 PM Thread Starter
calebsoldcj7
Also, the harmonic balancer bolt came off very easily which surprised me. I went to retighten it, and it tightened up a little bit, and then got loose again, as if it was stripped. The threads look fine however, is this a sign that there might be something wrong with the crank? Like the harmonic balancer bolt barely gets tighter then finger tight before getting loose again.
post #9 of 27 Old 08-29-2019, 11:00 PM
80cj
80cj's Avatar
1980 CJ5
Oh man I hate when that happens. How long is the bolt? Wonder if the previous owner stripped some of the crank threads trying to install the balancer with a bolt. Wonder if he installed the balancer with a bunch of locktite because the threads are screwed. Just speculating.
80cj is offline
post #10 of 27 Old 08-29-2019, 11:18 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Possible stripped bolt aside:
Try tightening up the puller till it feels like you're going to break something. Take a sledge hammer and dead blow the puller bolt. Most times this will "pop" the balancer off. Be sure you have the bolt and washer on there or it's possible to turn the balancer into a projectile.
Also a good technique for removing rear axle hubs.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #11 of 27 Old 08-30-2019, 06:54 AM
Hoover7
Hoover7's Avatar
Stripped crank bolt threads are frustrating, had the same thing happen on my 258 year before last. I ended up drilling and re-tapping the threads, and using a longer replacement bolt. Although I suspect the new threads aren't as strong, the bolt and balance have remained in place. Thanks for again your help on that one, 80cj.
As for removing the balance, I also had issues. In addition to all the good recommendations you've gotten so far, another thing that may help is ensuring that the threaded portion of the puller (where is passes through the duckfoot) is well oiled. I found that mine (made in china) was binding there, and oiling made it work much better.
Best,
Hoover
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #12 of 27 Old 08-30-2019, 07:41 AM Thread Starter
calebsoldcj7
Just did that, its just bending the puller, is it possible that i may need a nicer/stronger puller? If so which do you recommend?
post #13 of 27 Old 08-30-2019, 07:42 AM Thread Starter
calebsoldcj7
Its now the next morning and it sill hasnt budged. Its been soaking in PB, ive started to wail on the end of the puller with a hammer and then tighten then wail again then tighten. The puller is starting to bend, maybe i need a better stronger puller?
post #14 of 27 Old 08-30-2019, 09:30 AM
trailhead2004
trailhead2004's Avatar
1980 CJ7
Might be time for a new crank.
Rebuild the motor!
trailhead2004 is offline
post #15 of 27 Old 08-30-2019, 09:53 AM
80cj
80cj's Avatar
1980 CJ5
How good is your puller? Maybe rent a really heavy duty one. something that has a thick forcing screw with fine threads. As for the bolt in the crank get a short one about 3/4" long and drill a dimple in the center of the head to help center the puller. Make sure the bolt is bottomed out against the head in the crank before you start pulling. Grease the threads on the puller and have at it.
80cj is offline
