Hard Door Crack Repair - JeepForum.com
post #1 of 15 Old 02-11-2010, 05:29 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
How have you guys repaired your hard doors with the usual crack? Photos would be great. Thanks in advance.
nedmoore is offline
post #2 of 15 Old 02-11-2010, 05:32 PM
SpecFX
SpecFX's Avatar
I don't have any repair tips, but I do however have that exact same crack. I didn't know that it was a common thing among CJs.
I'll be interested to see what others have done as well.
SpecFX is offline
post #3 of 15 Old 02-11-2010, 05:44 PM
jeepwhore
jeepwhore's Avatar
jscherb has a good writeup on it. There might be a link to it in the Gaucho step side build thread or do a search for it.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4 of 15 Old 02-11-2010, 05:48 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
I do not know much, but I do know that it is a very common problem.
nedmoore is offline
post #5 of 15 Old 02-11-2010, 06:27 PM
yellow85cj
yellow85cj's Avatar
Start with post 997 here.
https://www.jeepforum.com/forum/f8/ga...2/index25.html
Currently in pieces - all of them
yellow85cj is online now
post #6 of 15 Old 02-11-2010, 06:28 PM
rrtex1
rrtex1's Avatar
1981 CJ7
Jeep Crack Kills!
Round Rock, Texas
1981 CJ7 AMC304
rrtex1 is offline
post #7 of 15 Old 02-11-2010, 06:32 PM
ZeroGravity
ZeroGravity's Avatar
It happens with early YJ doors as well. I've seen some guys clean up the crack and simply weld in the missing spot because it's narrow enough.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #8 of 15 Old 02-11-2010, 06:44 PM
illinicj
1979 CJ7
I had the cracks inside and out on both doors. When I stripped them, I found they had already been welded in all 4 places by somebody else and cracked again. I used jscherb's angle iron technique and they are holding up well so far, although it hasn't been long. The doors are much more sturdy now and I am confident it won't come back.
illinicj is offline
post #9 of 15 Old 02-11-2010, 06:47 PM
Bubba Ray
A buddy had this same issue and drilled the end of the crack before welding. So far so good.
Bubba Ray is offline
post #10 of 15 Old 02-11-2010, 07:53 PM
Daves77CJ7
1977 CJ7
I just had all my sheet metal professionally painted and I had those same exact cracks. I talked with the body man and he said that he ended upreinforcing the crack from the back side with something and welded it. He says it will not crack in that place again.
Dave
Daves77CJ7 is offline
post #11 of 15 Old 02-11-2010, 08:39 PM
_Kyle_
_Kyle_'s Avatar
Mine have the same ones... Hard Doors are only one 4-5 months or so out of the year so I guess I can live with it.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #12 of 15 Old 02-11-2010, 11:24 PM
apfroggy0408
apfroggy0408's Avatar
1982 CJ7
Hey I have the same cracks! I thought they might have been from replacing windows or something....
apfroggy0408 is offline
post #13 of 15 Old 02-11-2010, 11:43 PM
only in a jeep cj
No, its from slamming the doors too hard and flex in the doors from worn out weather seals.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 2003 Inca Gold TJ Rubicon
2012 JKUR RHD
only in a jeep cj is offline
post #14 of 15 Old 02-12-2010, 09:48 PM
wrongway92407
wrongway92407's Avatar
I drilled a hole at the bottom and then drilled a hole about 1/2" on both side and welded a piece behind and welded the crack to the piece also, ground it down and painted still good for 2 years. What I have noticed is when you close the doors the upper flexes, I try not to slam the doors but push them closed. I also have a 87 wrangler that has the wrangler package with the padded upper door panels and they haven't cracked.
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
post #15 of 15 Old 02-12-2010, 09:51 PM
wrongway92407
Not to change the subject, Ed, I used your idea on the frame nuts repair this week, worked great. Dave
Wrongway
My fleet:
Hard top repair rollcage Jeep CJ Forum 2 12-10-2009 09:05 PM
Hard door stress crack craigb86 Jeep CJ Forum 7 05-15-2008 04:27 AM
hard doors crack - pic omanalansanjr Jeep CJ Forum 9 11-07-2007 05:53 PM
Hard door repair? TheJunkMan2005 Jeep CJ Forum 1 06-08-2005 07:33 AM
Hard top repair ddavis Jeep CJ Forum 2 09-22-2004 07:01 AM
