Hand throttle - JeepForum.com
 5Likes
post #1 of 21 Old 02-11-2020, 10:46 AM Thread Starter
Jim1611
Jim1611's Avatar
Hand throttle
I have been giving some thought to rigging a hand throttle up and want to ideas, pros and cons. What do you folks think?
Thanks
Jim
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #2 of 21 Old 02-11-2020, 10:52 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I think it could come in handy on some tricky wheeling situations, Jim.
Doing the old brake/throttle with one foot and clutch with the other takes some practice. I can do it, but not very well. A hand throttle would help in those situations, I think.
Matt
Matt1981CJ7 is offline
post #3 of 21 Old 02-11-2020, 11:36 AM
Fourtrail
1974 CJ6
They can be handy, more so with a carb. But, your 5.0 with the IAC motor should do a decent job of increasing the idle when starting out on a hill and slipping out the clutch when still lightly on the brake. With 4.10's a t-18 and only 32" tires, you would need to be on a stopped pretty steep hill to need much additional rpm to get moving again. I did a quick look and didn't see an immediate answer, but you should be able to ground the correct pin in the wiring harness to make the computer think that the a/c compressor is on and that will kick you up to a higher idle.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 21 Old 02-11-2020, 11:53 AM Thread Starter
Jim1611
Jim1611's Avatar
Matt
My reason for thinking of this was on my way to a customer this morning I always stop by a boat ramp/access are to look around. The ramp is very steep and I thought of sometime putting a canoe in at that spot and it will most likely be from my CJ. The pedal dance here might get interesting or even water logged!
Had'nt thought of that of that. Thanks
My build thread
Jim1611 is offline
post #5 of 21 Old 02-11-2020, 12:57 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Sure you can do it electronically, but where is the fun in that?
Everyone needs an additional lever connected to that 4 speed anti theft device.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #6 of 21 Old 02-11-2020, 06:50 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
This was a big topic on this board a number of years ago.
Most folks used a bicycle brake leaver and cable mounted on the gear shift. This allowed you to throttle up and if you lost control, dropping the lever snapped the throttle back.
A search should bring up those threads.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #7 of 21 Old 02-11-2020, 08:46 PM
Axhammer
Axhammer's Avatar
Tj
Ive been thinking about a hand brake for the rear tires only. If you had a torsion style limited slip in the rear, and a hand brake to lightly apply the rear brakes, it would trick the limited slip into acting like a locker. This way you get the good road manners of a LSD on the street, but then in a tricky off road situation you could use the hand brake to get both rear tires working together when needed.
The hand brake could come in handy on a boat ramp if needed.
The E brake can be used the same way, but it takes a foot to activate it in a CJ-7.
Maybe a hand activated E brake like in my wifes 4runner...lots of cars came with a hand activated E brake.
The aircraft tugs we used in the Coast Guard always had a simple hand brake, that would lock when pulled back far enough to go over center, with and adjustment knob on the end to adjust the tension.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is online now
post #8 of 21 Old 02-12-2020, 05:07 AM
John Strenk
1976 CJ5
Like this?
post #9 of 21 Old 02-12-2020, 05:43 AM
Axhammer
Axhammer's Avatar
Yup...but the steering wheel looks lost.
post #10 of 21 Old 02-12-2020, 05:48 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Thanks
Jim
It would be fairly easy to do on the 5.0L EFI. The throttle cable bracket has a provision for the cruise control cable.
I cut that provision off my bracket, but later had the thought it would be nice to have a hand throttle for increasing RPMs during winching operations. Another 500-1000 RPMs would get the alternator charging the battery better.
But, in the end, I've not yet used my winch. And probably will just let it collect points at the mall.
"In the end...It's all Hack."
HackFabrication is offline
post #11 of 21 Old 02-12-2020, 05:59 AM
jeepdaddy2000
1971 CJ5
Two options, both hydraulic.
For parking try googling leverlok or parklok. Ebay also has some traditional hand brake style hydraulic units.
As for actuating your Gleason unit (or any single rear tire spin situation) you can go with a simple turning brake system. These are easy to find and are used extensively on dune buggy's and sand rails.
They come in either single or dual lever and will selectively slow/ lock one or the other tire.
Chesty Puller
post #12 of 21 Old 02-12-2020, 06:50 AM
John Strenk
1976 CJ5
Oh, just the thing to add a couple more anti-theft levers...
post #13 of 21 Old 02-12-2020, 10:13 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
Seems to me you could just repurpose a manual choke cable assembly and keep it on the dash........
CJ5_Fan is offline
post #14 of 21 Old 02-12-2020, 03:26 PM
StoneTower
I explored powering the AC idle bump on my 5.0 EFI swap and it seems the consensus was to supply 12 volts to the appropriate pin on the computer. The computer on Fords of that era supply the switched ground for circuits. I got sidetracked and never got back to it. I am a little afraid to just start hooking 12 volts up to that pin unless I know for sure because those A9L computers are in such short supply now. You should drive your Jeep before you figure out what else you need. When I am locked in low, my NV4500 in first gear can easily overpower the brakes idling at 650-700. When I am in 2 high, I can easily kill the motor on a steep hill because I almost always start in second gear. Starting in 1st solves this problem for the most part, but you have to shift at about 5 miles per hour. I was thinking of the electronic idle bump to use mostly on the street where a 200 rpm bump (that is what the computer does when the AC is powered on in a Mustang) would easily put the motor off the E303 cam's lumpy idle and closer to the powerband.
StoneTower is online now
post #15 of 21 Old 02-12-2020, 06:32 PM
jeepdaddy2000
1971 CJ5
LOL
Screw a NOx knob on the lever and see what happens at speed when he hits the gas...
Chesty Puller
