H1 steering gear box replacement - JeepForum.com
post #1 of 3 Old 06-17-2021, 01:30 PM Thread Starter
argh_o
Newbie
1980 CJ7
I bought a few Hummer H1 steering gear boxes AS-IS, so we will see what condition they are in (although look descent in the pics). Before picking one and installing it into my Cj-7, is there any way's of checking them out and determining what level of working condition they are in?
argh_o is offline
post #2 of 3 Old 06-17-2021, 01:47 PM
Axhammer
Axhammer's Avatar
Good question?
I know manual steering gears are pretty simple internally, but I have never been inside a power H1 gear. Years ago I bought a used one off of a first gen Camaro in a wrecking yard because it was tight, I could tell it wasnt worn because there was no slack or backlash between the steering shaft input and the pitman arm shaft. I took the guts out of it, and put them in my Firebird steering gear. The housings are different but the internals are interchangeable. I did that back in the nineties. The steering in my Firebird is still tight to this day after swapping those parts.
I would do a Google search on the H1 steering gear overhaul and go from there. Take them apart and use the best parts to make one good one, and new seals.
Why do I own a CJ? I like to Balance the wrench and the steering wheel
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35s on 2 Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #3 of 3 Old 06-17-2021, 02:45 PM
StoneTower
Take them to a shop and heave theme checked out???
Hook up the lines from the pump and see if they leak before installing them???
StoneTower is offline
