H1 Steering Box Brace - JeepForum.com
post #1 of 10 Old 10-23-2019, 10:45 AM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Assembling parts and curious for those that went with H1 box which one using to brace against passenger frame rail. It appears the one we have now may not mate to the box.
Tnx in advance.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #2 of 10 Old 10-23-2019, 02:28 PM
walkerhoundvm
walkerhoundvm's Avatar
1981 CJ8
I have the Rigged Ridge post-style brace and the TDK bracket on my H1 box.
walkerhoundvm is offline
post #3 of 10 Old 10-23-2019, 04:45 PM
RiverandSand
1980 CJ5
I have the M.O.R.E cross brace. It installed with no problems.
RiverandSand is offline
post #4 of 10 Old 10-23-2019, 06:54 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Ordered the more mounts And their bomb proof motor mounts. We discovered a number of frame cracks where the existing cross brace mounts to pass frame rail. A spider web of misery. Lots of torque happening here...fml.
Time to do this is now. Pulling the built 4.6 stroker. Seems the Teflon coated pistons failed and seals no longer doing the job, blow by plus other unwanted pain. Warranty expired 9 mos ago... poor compression # 5 & 6. Weee here we go!
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #5 of 10 Old 10-23-2019, 09:35 PM
RiverandSand
1980 CJ5
That sucks! Sorry for the misery.
I also have More bomb proof motor mounts for the SBC in mine. Nice set up had them welded in, liked them better than Novak's mounts. No cracks to date.
post #6 of 10 Old 10-23-2019, 11:37 PM
cpadget
cpadget's Avatar
1983 CJ7
I just completed this job about 2 weeks ago. MORE steering box bracket and MORE steering box brace. PM me for pictures
cpadget is offline
post #7 of 10 Old 10-24-2019, 11:28 AM
Spieg8
1984 CJ8
I don't recall who made the brace I have (I think most of them are pretty much the same), but when I switched to the H1 gear box, the old brace had to be modified a little to fit. I had to grind about 1/8" off one of the"clamp rings" so that it would clear the larger box diameter.
It's not the Voltage, but the Amperage that will kill you.
Spieg8 is offline
post #8 of 10 Old 10-24-2019, 09:57 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
What year range for the H1 should I search? Tnx in advance.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #9 of 10 Old 10-24-2019, 10:20 PM
RiverandSand
1980 CJ5
The H1 was produced from 1992 to 2004 I believe. So any of those yrs should do it. However it is getting harder to find one.
post #10 of 10 Old 10-24-2019, 11:29 PM
cpadget
cpadget's Avatar
1983 CJ7
Got mine at Rock Auto back in April
cpadget is offline
