Which H1 steering box for a '86 CJ7 - JeepForum.com
 4Likes
post #1 of 20 Old 07-28-2019, 10:42 AM Thread Starter
sertshark
There's a lot of info about the H1 upgrade for the steering system. Thinking seriously about doing it. Been looking for an H1, but I noticed a lot of different part #'s, and some of the ones mentioned on the board here seem unavailable. Is there a specific Part #/Year H1 box I should be getting for an '86 CJ7 with power steering? I want a direct bolt-on replacement with no upgrades (other than I'm getting an upgraded mount).
Should I be looking for a Cardone? That seems to be the make that is out there, but I'm not sure which Part # and/or year to get...
Year/Model: '86 CJ7 - Engine: 258 I-6 - Lift: Pro Comp 4" - Tires: 33X12.5 - Nuttered - Team Rush'd - Howell TBI
sertshark is offline
post #2 of 20 Old 07-28-2019, 11:03 AM
Spieg8
1984 CJ8
Part# will vary by brand. A box for 2002-2004 H1 will fit for sure.
It's not the Voltage, but the Amperage that will kill you.
Spieg8 is offline
post #3 of 20 Old 07-28-2019, 10:32 PM
AndrewUVM
I have a Lares 1430 H1 steering gear in mine.
AndrewUVM is offline
post #4 of 20 Old 07-30-2019, 03:39 PM
4milechuck
Junior Member
4milechuck's Avatar
1983 CJ8
I did the H-1 installation about 4 years ago. Got unit from Auto Zone "Endurance Steering Gear" #7564. It was a direct bolt in, shaft same size & spline count. Think it was a Cardone rebuilt unit. No problems & works exceptionally well.
4milechuck is offline
post #5 of 20 Old 07-30-2019, 07:01 PM
acgcoug
acgcoug's Avatar
1979 CJ5
Lares 1430 H1 as well. Easy install, no issues so far driving, and buttery smooth. Those with older CJ's, I believe anything '79 and older like mine, with flared ps lines need to go with 80's CJ ps lines for it to work (or custom fittings). Outside of that, the Lares or Cardone unit should mount right up without any changes needed to any 80's CJ.
Also a good time to upgrade to an HD mount as well.
Cutlass327 likes this.
_________________________
Adam's 1979 CJ5 Frame-up build:
acgcoug is offline
post #6 of 20 Old 07-31-2019, 01:09 PM
Spieg8
1984 CJ8
An 86 CJ should use metric flares... same as the Hummer. No adapters required.
CSP likes this.
Spieg8 is offline
post #7 of 20 Old 07-31-2019, 01:26 PM
CSP
I'd take a Lares box over Cardone any day.
CSP is offline
post #8 of 20 Old 07-31-2019, 03:29 PM
Shadow86
Shadow86's Avatar
So it looks like these are getting more difficult/expensive. The cardone one is no longer available on Rockauto, the lares one is only available for rebuild, and the endurance steering gear from Auto zone is no longer available. Advance Auto has nothing. Rockauto has an ACDelco one, O'Reilly's sells a MasterPro branded one, and Napa appears to have one available as well.
Not sure which would be considered the best quality but they are all remanufactured.
Whatever you choose, let us know the initial quality!
Shadow86 is offline
post #9 of 20 Old 09-07-2019, 09:52 PM
CJOO7
Hey....I am curious if you got one and which one you got. I was looking at the ACDelco one. The Lares one cost about $80 more. Is the Lares worth the extra money?
Thanks
*1945 Willys MB
*1984 CJ7
CJOO7 is offline
post #10 of 20 Old 09-08-2019, 01:01 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
subscribed
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #11 of 20 Old 09-09-2019, 08:31 AM
NormWild
I got the Lares 1430 one from Rock Auto, bolted right in, works great, no issues. I don't know how they keep accepting CJ boxes as cores given they are not the same thing, but not complaining. Strongly recommend upgrading the bracket while you are at it.
1985 CJ7- Too many mods to list due to stupid 100 character sig restriction
NormWild is offline
post #12 of 20 Old 09-11-2019, 07:41 PM
CJOO7
Thanks for the info. My steering box is leaking so bad I am leaving a trail of power steering fluid everywhere I go. Looks like I live about an hour away from you!
whollsee and NormWild like this.
*1945 Willys MB
*1984 CJ7
CJOO7 is offline
post #13 of 20 Old 09-20-2019, 12:26 PM
NormWild
Good Luck! Sounds like your pitman arms shaft seal took a dump. I live down by Blue Mountain Ski Area.
NormWild is offline
post #14 of 20 Old 09-22-2019, 02:23 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Probably why they are getting harder to find - no cores returned to rebuild to put back into circulation.
I just have a hard time believing that there are not others vehicles that this application would work on too. I cannot see these people designing a steering box for 1 make of vehicle. And being how many H1s are out there, parts have to be available everywhere for them!
Maybe we need to start looking at military salvage yards or surplus suppliers for them?
Rick
Cutlass327 is offline
post #15 of 20 Old 10-04-2019, 03:01 PM
cpadget
cpadget's Avatar
1983 CJ7
Finally dig into yesterday. Packaged the faulty core today and will tackle the install of the Lares 1430 once the steering shaft arrives. Luckily I don’t deal with rust in the Southwest. Steering shaft came off very easily.
cpadget is offline
