Gun/Fishing Pole Rack - JeepForum.com
post #1 of 10 Old 07-08-2020, 06:24 PM Thread Starter
scottyDive
So, I bought a set of these racks off of ebay without doing a lot of thinking about it. I thought it would be great for carrying a fishing pole or two. I have no idea how these install. Am I correct in assuming they mount on the inside side window on a hard top? Seller said they were from the Special Equipment Jeep catalog if that helps any
Scott
86 CJ7 Laredo
84 CJ7 Renegade
70 Jeepster
scottyDive is offline
post #2 of 10 Old 07-08-2020, 06:36 PM
John Strenk
John Strenk's Avatar
1976 CJ5
You have a picture or link to the racks?
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #3 of 10 Old 07-08-2020, 06:55 PM Thread Starter
scottyDive
Sure do.
The height is adjustable as well
Sent from my SM-G960U using Tapatalk
Scott
86 CJ7 Laredo
84 CJ7 Renegade
70 Jeepster
post #4 of 10 Old 07-08-2020, 07:15 PM
LumpyGrits
Those are rifle racks and you mount the holders in a vertical position.
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #5 of 10 Old 07-08-2020, 07:22 PM
John Strenk
1976 CJ5
Wow, Easy Rider Rifle Racks.
Haven't had a set those since I sold my truck.
Great for hanging your hard hat on also.
How are you planning on mounting them? You will probably have to drill through the top.
Probably special equipment for Jeep Pickup, Not a CJ.
This is how they usually are mounted:
post #6 of 10 Old 07-08-2020, 10:02 PM
REDnBLUES
REDnBLUES's Avatar
1977 CJ7
Wow, haven't sen one of those hat racks in years either.
Nice photo
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
post #7 of 10 Old 07-09-2020, 08:39 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
For fishing rods, you have a couple of options. You can go with a hood mounted system (very popular in my neck of the woods) or an inverted style rack mounted either on the roll bar (depending on your configuration) or on the passenger side of the rig with the rods on the outside. Both of these systems allow for you to carry the rod set up complete with the reel. If you don't mind breaking them down, a simple aluminum/plastic rod storage tube will do the trick. If you don't want to buy a tube, you can make a cheap one out of PVC pipe.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #8 of 10 Old 07-09-2020, 09:51 AM Thread Starter
scottyDive
I will probably get rid of these since I run with only a softop at the most. Easy enough to make a rack that slides into the reciever hitch i have.
Scott
86 CJ7 Laredo
84 CJ7 Renegade
70 Jeepster
post #9 of 10 Old 07-09-2020, 11:21 PM
RedNeckCorvette
1979 CJ7
I have them in my retired 3/4 ton 4x4 service trucks and they work great holding a 4' level or a set of plans in the off season, but there isn't room enough for them in my the CJ7. Most rifles 24'' & 26''or shot guns 28-32 barrels are to long to fit in the jeep sideways.
RedNeckCorvette is offline
post #10 of 10 Old 07-10-2020, 06:10 AM
jeepdaddy2000
1971 CJ5
Are you carrying your rods vertically? Seems that without some sort of secondary support the tippets are going to get whipped around at highway speeds.
Chesty Puller
