Grinding from transmission or transfer case and loss of 2high - JeepForum.com
 2Likes
  • 1 Post By only in a jeep cj
  • 1 Post By cjoffroad
post #1 of 10 Old 10-20-2019, 09:16 PM Thread Starter
Anderscj8
I was experiencing violent grinding from my transmission or transfercase when slipping the clutch every once in a while. The noise went away so I decided it was okay to off road. After pulling off the trail I tried to put the car in 2high and the car wouldn't move, so I was able to limp it home in 4high using the front wheels to drive the car. Does anyone know what the grinding is and how I could get 2high back?
(the car is a 1982 cj8 scrambler with a cj7 v8 swap)
Thank you all for your suggestions. I ended up taking it to a local shop and they believe I blew up the differential.
Anderscj8 is offline
post #2 of 10 Old 10-20-2019, 09:34 PM
Trapshooter
Trapshooter's Avatar
First off It would be good to know what type of tranny and transfer case you have in your Scrambler. You should fill out your profile when you get a chance.
Have you performed any type of troubleshooting? Check to make sure your shifter and transfer case linkage hasn't worked loose. Get under the Jeep with a strong flashlight and look for anything abnormal.
BTW.....Welcome to the Jeep Forum!
Good Luck............
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 10 Old 10-21-2019, 10:07 AM
Hurricane4
1979 CJ5
To add to what Trapshooter said also list wheel and tire size at each corner (I have seen people wheel with different diameter tires = bad) - list any lift, type and height lifted = possible severe driveline angles. The list goes on but check basics like all fluids - transmission, transfer case & axles. You said you drove home with only the front tires/axles pulling the Jeep. How did you know there was no power to the ground on the rear tires/axles?
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #4 of 10 Old 10-21-2019, 10:09 AM
Hurricane4
1979 CJ5
Also- Is this Jeep “New to You”?
Winston Churchill
post #5 of 10 Old 10-21-2019, 11:19 AM
only in a jeep cj
My guess is stock 2 piece rear axles with a spun hub on one side.
Trapshooter likes this.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #6 of 10 Old 10-21-2019, 11:52 AM Thread Starter
Anderscj8
The only way to check for power to the rear wheels we could think of was spinning the tires on the dirt. I tried to get the tires to spin and only the front wheels spun. The rears seemed to just getting pulled by the fronts.
post #7 of 10 Old 10-21-2019, 11:53 AM Thread Starter
Anderscj8
Yes. I purchased it a little over two months ago.
post #8 of 10 Old 10-21-2019, 11:55 AM Thread Starter
Anderscj8
Could that also explain the grinding while driving?
post #9 of 10 Old 10-21-2019, 12:06 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes, quite a bit.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #10 of 10 Old 10-21-2019, 08:09 PM
cjoffroad
cjoffroad's Avatar
1980 CJ7
To add to the things to check. Make sure your axle gear ratios are the same
Hurricane4 likes this.
cjoffroad is online now
