JeepForum.com (https://www.jeepforum.com/forum/)
-   Jeep CJ Forum (https://www.jeepforum.com/forum/f8/)
-   -   Going to buy a 81 cj-5 on wednesday.... (https://www.jeepforum.com/forum/f8/going-buy-81-cj-5-wednesday-4371249/)
Submariner 09-15-2019 04:23 PM
I am going down to look/buy a 81 cj5 on Wednesday. Today is Sunday.
Any words of wisdom on what I should look at.
I was told that this had been in the family for 30 years. California jeep, no rust, but it has been wheeled. not sure how hard but it is in central oregon now.
It has a newer disk brake set up on the dana 20, and all the steering components has been gone thur, it has the 258 cu in with a 4sp tranny(granny low) in it. good soft top, 12000 winch, 31 in tires, rubicon rack(?) on the back.
another ole guy is selling it to another ole guy buying it. I am driving 200 miles to look/buy it.
So what I am asking, is what else should i look for when I get there to buy it.
Thanks
John Strenk 09-16-2019 05:57 AM
Probably look for bent/cracked items.
If it has diamond plate, well, as you know, that hides a lot of rust.
Are you driving it back?
Might want to check fluid levels. if it's not leaking, it may mean it's out of oil.
See if the gauges work. I'd be a little leary of driving 200 miles if the temp and oil gauges are inoperative.
As far as gas goes gauge goes, carry a can and assume 10 mpg. that should be safe enough.
Make sure the electrical system is working incase it gets dark and you need heat and lights. Just check the volt meter and make sure it's around 14 volts with the engine running.
Check the u-joints. The front one not so bad if it has unlockable hubs.
Any chance of rain? Make sure the wipers work. Blades in good condition.
Submariner 09-16-2019 09:30 AM
good Idea. i know some guages stop working on the older rigs. Water, oil and electric is always good to know what is going on. Especially when Ihave to drive back 200 miles
mc190 09-16-2019 09:50 AM
CJ-5 are somewhat small. About 8 yrs ago was shopping for my older son's first car- had to be a manual, we decided on a Jeep. Looked at a CJ-5 that was in our price bracket. I'm 6'4" and 260lbs. I had a hard time getting in/out of the CJ-5. At the time my son was around 6' tall, and pretty lean. His knees hit the steering column
So unless you've been in one just know they are not for "bigger" people.
We ended up with a 89 YJ. No issues with the "size"
Submariner 09-16-2019 10:31 AM
I have had a "5" before. that is why I am going back to "ole" school. Tired of dealing with all the sensors and computers. If I remember right, 81 does not have a computer and it went with a wider version of axles and this one has been shifted over to disk brakes in front.
I am just looking for items that I don't remember to check. getting old in the memory.
Or am I wrong with this thought?
John Strenk 09-16-2019 10:38 AM
Yep, No computer. Just an Idle Speed Controller.
Nope. The CJ-5 never got the wider axles unless someone swapped them in.
trailhead2004 09-16-2019 03:57 PM
Submariner, sent you a PM.
MrButterfield 09-16-2019 05:54 PM
If it's the light blue one (Im in Oregon and quite sure i know which on you're after) why not just post the ad? These guys can spot a lugnut torqued out of sequence from a grainy photo on the grassy knoll.
BagusJeep 09-16-2019 07:53 PM
Sounds like it is not lifted (31" tyres are the max you can go on stock) and has a middling spec. Whether to buy goes on condition. If you are happy with the space and short wheelbase, the main area to look at is condition.
Interiors can be very basic but to replace original trim and sets etc can get very expensive, there are no many left out there. Gauges and such are readily available but a cut up dash is a pain. Wiring is usually shot, it can all be replaced or by dropping the instrument panel some sense can be made out of it. I look for fusible links being in place, a fuse box, indicators on the column and a working ignition lock/switch, not beacuse they are expensive but because their elimination shows a PO mentality that may stretch to engine oil changes etc. Every other electrical or interior fault is an irritation that can be fixed.
Rust, rust, rust. It can be repaired, but is PITA.
Suspension and axles and transmission, steering etc should all work. Replacing TRE etc is quite easy but a disconnected front axle is a red flag. Money can fix all these areas.
Lastly, all PO mods are questionable. few add value. i do not pay for mods.
Submariner 09-17-2019 09:11 AM
Thanks for the advice guys. I will go see this tomorrow or on Saturday depending on the amount of rain that is going on.
I forgot to add that it has a 12,000 lb winch on the front. a little over kill if you ask me.
John Strenk 09-17-2019 09:34 AM
Overkill is so underrated...
bob4703 09-17-2019 10:13 AM
40 years ago I had a Power Wagon which weighed slightly less than 5000#. The formula recommended to me to figure the appropriate size winch was double your vehicle weight and add a 1000#. Buy the closest size winch without going smaller. I bought a 12000# winch. Which size that is on sale is also also a factor.
In that it is also on the Jeep and you probably won't pay extra for it it isn't overkill. Better overkill than underkill if you need it.
JoonHoss 09-17-2019 02:53 PM
If it's the light blue one in cottage grove, the tub/ front look pretty hammered, IMHO
Hoss
BagusJeep 09-17-2019 07:36 PM
If you use a winch regularly the ultimate pull (12,000 lbs) does not tell the whole story. Nice to have in an emergency as your Jeep is decending a sheer cliff, though.
trailhead2004 09-18-2019 01:15 PM
Hoss
Not sure what you guys consider Central Oregon, but just outside of Eugene isnít CO. Maybe he misspoke.
The time now is 03:12 PM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
