To gasket or not to gasket, that is the question. - JeepForum.com
 23Likes
post #1 of 29 Old 08-13-2020, 07:13 PM Thread Starter
Horatio
1980 CJ7
1980 258. The TSM provides instructions for both a gasket method and an RTV only method. I currently have a leaking cork gasket. Is anyone using only RTV with success?
Horatio is offline
post #2 of 29 Old 08-13-2020, 07:47 PM
Wabatuckian
Wabatuckian's Avatar
20 years ago, I never had much success with silicone on my CJ. Today, I might consider some of the new offerings.
However, I'd most likely still go with a gasket.
Josh
Wabatuckian is offline
post #3 of 29 Old 08-13-2020, 08:00 PM
4Low2G0
4Low2G0's Avatar
what gasket are we working on? Valve cover?, I go with the gasket and some sealer, don't
over tighten or you'll crush the gasket and have leaks.
also be sure the cover has a good flat mounting surface. you may have to work it flat again where the bolts go.
Whats over that next ridge?
4Low2G0 is offline
post #4 of 29 Old 08-14-2020, 12:05 AM
ddawg16
ddawg16's Avatar
It would help to say which gasket. But I'm going to assume you mean the valve cover.
No gasket....RTV
This is what worked for me.....
1. Take apart. Clean everything real well.
2. Using Black RTV, run a 1/4" bead of RTV (silicone) around the edge of the valve cover.
3. Real important.........wait at least 30-45 min until that bead is tack free (it doesn't stick to your finger)
4. Carefully place into position. Gently snug the nuts. SNUG!!!!!!!!!!
5. Real Real Real important...........grab a few beers and relax for the evening. Don't touch it. You need to let the RTV cure.
6. Now you can tighten the nuts down
You now have a perfectly formed gasket. It has worked well enough for me I could remove the valve cover and put it back down and it didn't leak.
dln1962 likes this.
ddawg16 is offline
post #5 of 29 Old 08-14-2020, 01:47 AM
80cj
80cj's Avatar
1980 CJ5
On valve cover and rearend I use gaskets with Permatex aviation form a gasket. No leaks.
RedNeckCorvette likes this.
80cj is offline
post #6 of 29 Old 08-14-2020, 05:42 AM Thread Starter
Horatio
1980 CJ7
Yep, sorry folks. I'm doing the valve cover.
ddawg, thanks for your instructions. I think I'm going to give this a shot. I'm also considering using Nord-lock washers.
Horatio is offline
post #7 of 29 Old 08-14-2020, 07:50 AM
bob4703
1974 CJ5
Consider no other gasket than a Felpro. Tighten in stages and never over torque. Check the tightness of the bolts after a few weeks.
80cj, RedNeckCorvette and Horatio like this.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #8 of 29 Old 08-14-2020, 11:25 AM
verreaul
verreaul's Avatar
1976 CJ7
I used Permatex The Right Stuff on differential covers and plastic valve cover.
Differentials are going on 3 years with no leaks and I just did the valve cover in the spring (also no leaks to date).
commadore64 and dln1962 like this.
verreaul is offline
post #9 of 29 Old 08-14-2020, 11:39 AM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Valve cover?
A nice even and thin coat of RTV on the gasket.
Install gasket on valve cover.
Use clothes pins to hold the gasket in place.
Make the clothes pinning resemble thirsty cattle around the water hole, and none of 'em will let one more in beside them!
Once the RTV is dry, apply another coat to the bottom side and install the cover on to the head.
I have one more observation you don't wanna see yourself (I already done it for you!).
If you put RTV on both sides and install it (without one side drying first) As you snug the bolts down, the RTV is so slick it will allow the gasket to suck under between the bolts----it will leak!
If y'all would like to hear and see a horror story of "Gobbing" RTV on drive train stuff, I'll be glad to take the time to show you that! I seldom use RTV, It does have it's place. I categorize gaskets as "Squishy" or "Non-Squishy". I might use this on either type. For sure, on the "Non-Squishy", 99% of the time I use "GASKET SHELLAC" (Indian Head [brand]) on things like the timing chain cover gasket/ the fuel pump gasket/ water pump gasket/ yes, even intake and exhaust manifold to the head and to the carburetor/ and lots more.
Back to the horror story!
I use the Gasket Shellac on the gaskets for the tranny and the shift assembly/ covers on the transfer case/ the covers on both differentials
A few years back, I found that the previous owner had Gobbed RTV on the transfer case cover.
I found it way too late!
I snatched the tranny out for a rebuild, My plan was to do the transfer case later. I set it off to the side.
I perfectly replaced every part inside the tranny--100% perfection!
I reinstalled it and the transfer case.
Five miles down the road and at 55 MPH later, the rear of the Jeep locked down and I began sliding sideways. I was saved by my "cat-like" reflexes.
OK, I'll speed through what happened.
I must have stirred up the "GOBs" of RVT in the bottom of the case when It was off.
The GOBs got into the rear bearing cap and closed off the oil holes to the rear bearing (this is the cast iron part that the yoke comes out of the transfer case)
The bearing starved and locked down, the torque from the 55 MPH driveshaft snatched the seized rear bearing cap and this torqued the case and cracked it too.
Everything in the cap was cooked and broken, like the speedometer stuff.
Winter time/ funds were scarce/ her rig lost it's tranny/ Now "Mr. Jeep" was down/ All that was left was "Willy"!
See us in here! https://www.jeepforum.com/forum/f8/r...-area-4323145/
Sorry my pics are not in order.
If y'all had been there,
You coulda watched me cry like a little girl.
----JEEPFELLER
Horatio likes this.
JEEPFELLER is offline
post #10 of 29 Old 08-15-2020, 07:37 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Another vote for The Right Stuff by Permatex, with no gasket.
Matt
commadore64, Horatio and dln1962 like this.
Matt1981CJ7 is offline
post #11 of 29 Old 08-15-2020, 09:43 AM
oldschool74cj5
hello
i used a mahle gasket with the metal shim in between the two pieces of cork. being in aviation i used a thin coating of permatex aviation gasket make on both sides. then made sure to torque all the bolts. the nice thing about the aviation gasket maker is it cleans off with alcohol or other cleaners pretty easily. it dries but never truly hardens.
oldschool
Horatio likes this.
oldschool74cj5 is offline
post #12 of 29 Old 08-16-2020, 06:22 AM Thread Starter
Horatio
1980 CJ7
Matt
I'm going to give this a shot. Doing some Amazon shopping I found a couple different Permatex options:
Permatex 27037 Optimum Black Gasket Maker
and
Permatex 25228 The Right Stuff 90 Minute Gasket Maker
Why The Right Stuff over the Optimum Black?
Horatio is offline
post #13 of 29 Old 08-16-2020, 06:35 AM
Matt1981CJ7
1981 CJ7
For me, it was because my FLAPS carried the Right Stuff in stock, but not the other stuff.
Matt
post #14 of 29 Old 08-16-2020, 06:46 AM Thread Starter
Horatio
1980 CJ7
Matt
Had to look up FLAPS!
Found a comparison chart. Think I'll give the optimum black a shot.
Permatex.pdf
Horatio is offline
post #15 of 29 Old 08-16-2020, 07:12 AM
cjoffroad
cjoffroad's Avatar
1980 CJ7
The right stuff, as I understand it, has the ability to be torqued and put into use right away... as the others need to setup before
cjoffroad is offline
