LinkBack | Thread Tools |
Looking for a high-res color wiring diagram for a 1985 CJ7. Links?
Thanks all
Thanks all
1985 CJ7 258 I-6 4" Rubicon Express on 33's - Soon to be primer color ;)
Sponsored Links | |||
I also have a question regarding the 1978 color diagram that you can find out there. What is this item circled in red? I don't believe I have that in my 1985 CJ7...
You have one but it looks different in the older vehicles...
It's called a fuse block
When I was younger, I thought I was Don Quixote... turns out I'm just another donkey-hootie.
Around 1979, AMC went with a newer style fuse block. Probably like the one you have on your now.
Most circuits stayed the same, a few circuits changed. Most of the colors stayed the same
Just ignore the color error on the low/hi beams.... I was concentrating on the circuit numbers..
I drive a Prius to save money and buy more Jeep Parts....
Originally Posted by John Strenk
View Post
Thanks
The numbers are circuit numbers that you would find in most schematics of the CJ. I was just pointing out the circuit number's colors stayed the same up until 1982. Then they started to mace changes in the nomenclature although the colors and gauge remained mainly unchanged.
The Letters on later CJ's matched up with the letter designation on the bulkhead connector.
Thanks for the wiring diagram link. Very helpful!
Hello,
In going through this post I ended up a little confused. The original poster seems to have been working on an 83 CJ7 (or at least that is the only model in their signature). Can someone clarify what years this diagram covers? I am working on an 83 CJ7 that was left out in the desert for about 15 years and I am working to solve some light issues.
Thanks
Thanks
Originally Posted by kmorgan
View Post
Hello,
Thanks
Thanks
This puts it in the range of 76 to 77.
Definitely not for an 83.
I'll see if I can find an 83 schematic someplace. I can't access my files onl;ine anymore.
Ok I know this is old but it is awesome. I just solved a backup light problem in less than 30 minutes. I know I am going to love this site. I have found a ton of information already just with the search function. This is my second jeep and it seems over the years the PO's just can't keep control of the wiring and though my current is no where near as bad as my last one it is still a mess.
Great Site!!
Great Site!!
Tags |
cj , diagram , wire harness , wire identification |
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Similar Threads | ||||
Thread | Thread Starter | Jeep Forums | Replies | Last Post |
CJ-7 Full Steel Door Diagram? | cfljeep | Jeep CJ Forum | 9 | 11-28-2012 03:19 PM |
need wiring diagram | pistol | Jeep CJ Forum | 7 | 12-09-2009 08:01 PM |
Wiring diagram for 77 CJ5 | spankyway | Jeep CJ Forum | 11 | 08-16-2007 09:27 PM |
360 wiring diagram | coyote7791 | Jeep CJ Forum | 3 | 08-05-2007 03:26 PM |
CJ-7 Wiring Diagram | Esquilax | Jeep CJ Forum | 2 | 08-23-2004 12:12 PM |
Posting Rules | |
