Fuel tank install - without the old one as a guide... - JeepForum.com
 8Likes
post #1 of 20 Old 09-20-2021, 06:06 PM Thread Starter
Islander13
Islander13's Avatar
1981 CJ7
I could use a little guidance here. My new to me '81 CJ7 came without an installed fuel tank. There was one bolted in that the previous said he bought used but wasn't the right one.
So I've ordered a replacement Spectra and an Omni-Ada sending unit. Without taking out the old one, I have to figure out where to connect the lines. I have to wait at least a few days for the new tank/sending unit, so just doing some advance research. I've seen tank removal videos, but not straight up installs. So I'm assuming that:
the the fuel lines connect to the sending unit via fuel safe lines rubber lines that I'll have to pick up.
The vent lines connect directly to the vent side of the tank
The fuel fill and vent hoses connect directly to the tank
I think that's straight forward, but I was confused seeing the old tank with fuel lines that connected in a 'Y' fitting.
Any advice is appreciated.
I should note hat the undercarriage is in good shape. I did run my borescope up the fuel fill lines and they looked good. I can't fit the scope up the metal fuel lines to the pump.
Islander13 is offline
post #2 of 20 Old 09-21-2021, 08:17 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Maybe this is start for you
Others will probably help out too
This is what a '81 tank looks like
https://www.carparts.com/details/Jee...E&gclsrc=aw.ds
This is a diagram for a '77 from the factory service manual. The filler end has the correct kinda parts, it may be configured a a bit different on an '81 (routed different--I'm not sure)-------the vent end is the same from '76-'86 (you can see what is missing on yours) Maybe someone has the '81 diagram for you.
-----JEEPFELLER
Islander13 likes this.
JEEPFELLER is offline
post #3 of 20 Old 09-21-2021, 08:56 PM Thread Starter
Islander13
Islander13's Avatar
1981 CJ7
Thanks Jeepster. I love the schematic. This '77 diagram only has one fuel line forward to the pump.
My sending unit has two connections as well as the electrical. I also have 2 metal fuel lines going forward. I read somewhere that the extra line is a return line that they added for emissions.
Ken D
1981 CJ7
258 4spd
post #4 of 20 Old 09-21-2021, 09:11 PM
Girth83
1982 CJ5
Here's a pic of the tank/lines from my 1982 TSM. Bit different layout than the '81 tank it looks like, judging by the link JEEPFELLER posted, but some of the same features maybe?
Girth83 is offline
post #5 of 20 Old 09-21-2021, 09:31 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Girth83 repost the diagram, it did not show.
The return serves 2 purposes I know of.
To keep from over pressuring the needle and seat inside the carb
and
To keep fuel moving---this prevent the fuel from staying in one place and being overheated by exhaust related parts---this would possibly cause "Vapor Lock" and keep fuel from reaching the carb.
Pic of what the other end looks like----the regulator and gauge are addons on my Jeep. Pic 1 was used explain elsewhere.
Pic 2- that's the return line connected to the down side of my regulator. (this configuration works the best to control pressure to the carb)(believe it or not)
Insure you don't switch the suction line (connected to the long tube and screen) with the return (sorta dumps back in from up higher)
-----JEEPFELLER
post #6 of 20 Old 09-22-2021, 03:29 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
The electrical connection was to the fuel gauge sender. It is a single wire (pink if I recall). To get better readings you can install a black wire of the same size to the metal structure of the sender unit and run it all the way back to the instrument cluster holding down bolt.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #7 of 20 Old 09-22-2021, 11:11 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes, pink is for the fuel. And the other one is a ground connection.
I guess you couldn't trust the sending unit to maintain a good ground connection.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #8 of 20 Old 09-22-2021, 01:51 PM Thread Starter
Islander13
Islander13's Avatar
1981 CJ7
Thanks to all. I realized last night after looking at the old tank again that the merged lines in the 'Y' in the one pic are actually the vent lines not the fuel supply and return lines. That was confusing me.
I did follow the lines off the fuel filter and one goes to the carb and one does return back to the tank.
So I should have everything I need except for some fuel safe 5/16" and 1/4" rubber lines to connect from the metal lines to the sending unit.
Because I didn't take the old tank out, I'll have to re-source the bolts to attach the skid plate/tank to the chassis. The new tank and sending unit should be here within a week. The old pan/skid plate is in good shape so I will reuse it after a good wire brushing and some POR15. I have ordered new straps though.
Ken D
1981 CJ7
258 4spd
post #9 of 20 Old 09-23-2021, 12:12 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
The bolts which hold my skid plate / tank cradle on are coach bolts. The square end under the head allows them to sit in the square holes in the body and hence do not turn when you offer up the tank and put on the nuts. Very thoughtful of AMC to put them on, it is one of the few things about the whole drop tank thing that is made easier.
post #10 of 20 Old 09-23-2021, 06:34 AM
keith460
keith460's Avatar
I tried to upload photos yesterday from my hotel but bandwidth too slow I guess.
Try again....
1984 CJ-7 Renegade
keith460 is offline
post #11 of 20 Old 09-23-2021, 06:39 AM
keith460
keith460's Avatar
And some more.
1984 CJ-7 Renegade
keith460 is offline
post #12 of 20 Old 09-23-2021, 09:01 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by keith460 View Post
And some more..
Keith, when you took all of the photos of your build years ago, did you have any idea you'd be re-posting them regularly in order to help people?
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #13 of 20 Old 09-23-2021, 09:46 AM
Nor Cal CJ5
Nor Cal CJ5's Avatar
1972 CJ5
Great Photos Keith!
I thought of another bit of help that the OP may need and maybe John Strenk can chime in on. Before you get the tank back in completely, you may want to calibrate the fuel gauge so it accurately depicts the amount in the tank. I’m unsure if there is an adjustment on your year model or not, but I remember difficulties with this when my my in-tank sensor was replaced some +20 years ago.
keith460 and Islander13 like this.
1972 CJ5 304 V8, 3 speed manual trans
Nor Cal CJ5 is offline
post #14 of 20 Old 09-23-2021, 01:34 PM
keith460
keith460's Avatar
Yes I did. Most JF members don't know how or use the search feature and results don't always give you what you want without reading through many post. Key Words are really the only way to narrow down the search to find a specific item one needs info on.
1984 CJ-7 Renegade
keith460 is offline
post #15 of 20 Old 09-23-2021, 02:31 PM Thread Starter
Islander13
Islander13's Avatar
1981 CJ7
wow... Thanks Keith. Those pics are great. Without pulling the tank out - there were a couple of mysteries. You pretty much cleared most of them up with those pics. Thanks!
Ken D
1981 CJ7
258 4spd
