Front Main Seal Project Prep Post - JeepForum.com
post #1 of 4 Old 10-16-2020, 10:25 AM Thread Starter
waltonwj
waltonwj's Avatar
1980 CJ5
Time for the next project! I have a buddy coming in next week to help me stop the oil leak I’ve got on the front of my 258ci.
I have a puller, and am about to order the front main crankshaft seal and new belts. I also see that there’s a gasket on the timing cover.
Before I place my porder, is there anything else that’s good to replace on the front of the engine while we’re in there? Needed parts/tools?
Thanks!
waltonwj is offline
post #2 of 4 Old 10-16-2020, 11:04 AM
Fourtrail
1974 CJ6
Check the slack in your timing chain. If there is excessive and you are going to have the timing cover off, might as well replace it.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 4 Old 10-16-2020, 04:06 PM
oldschool74cj5
hello
also really look at your harmonic balancer and see how worn and dry rotted it is. you probably have a large ring worn in from the seal. the new seal will work for a short time but start leaking again. they make a repair seal that comes with a thin sleeve that you can press on the harmonic balancer to give a new surface or just change the harmonic at the same time as the seal.
oldschool
oldschool74cj5 is offline
post #4 of 4 Old 10-18-2020, 08:10 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Some stuff they discussed
Never pull on the outside of the harmonic balancer!
I removed my grill and radiator which made things a bunch EZer.
My mission was to install a new timing set, my chain was scraping the inside of my timing cover.
I went with a Cloyes true roller set.
MR. JEEP TIMING SET 100.jpg   MR. JEEP TIMING SET 113.jpg   MR. JEEP TIMING SET 112.jpg   MR. JEEP TIMING SET 111.jpg   MR. JEEP TIMING SET 139.jpg
JEEPFELLER is offline
