frame off restoration...underside of tub - JeepForum.com
post #1 of 22 Old 02-03-2009, 02:31 PM Thread Starter
codyp8
1983 CJ7
im working on a frame off restoration of my 83 cj7 and was wondering if i should go through the trouble of paying much attention to the underside of the tub. i am going to herculiner the inside of the tub and was thinking about maybe doing both sides or just going with a simple undercoat what do you guys think from experience?
codyp8 is offline
post #2 of 22 Old 02-03-2009, 02:37 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
If there is any rust rmove it then herculiner the underside.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #3 of 22 Old 02-03-2009, 02:47 PM Thread Starter
codyp8
1983 CJ7
thanks thats what i had planned on doing but i gues i just needed some reassurance. has anyone ever used the roll on herculiner is it as hard and time consuming as i anticipate
codyp8 is offline
post #4 of 22 Old 02-03-2009, 02:53 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Me and alot of the guys used this:
http://www.tptools.com/p/2600,233_U-...Liner-Kit.html
Very easy and comes with the spray gun, about $109 to my door. Sprayed it last year and in this Hot Florida all year with NO top it still looks great.
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #5 of 22 Old 02-03-2009, 05:34 PM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I cleaned it all up and used Duplicolor... came out sweet.
What it was
http://www.certifiablejeep.com/image...e/100_1111.jpg
What it is now
http://www.certifiablejeep.com/image...e/100_1150.jpg
2 coats and it really came out good...
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #6 of 22 Old 02-03-2009, 05:50 PM
Coiz
Coiz's Avatar
1979 CJ7
^^ Duplicolor paint or is that the Duplicolor bed liner? How much did it take to cover that area, quantity and $$$?
Mike
Coiz is offline
post #7 of 22 Old 02-03-2009, 06:02 PM
Bard
I would spray it, not roll it. Too many curves and hidden channels. I just used rubberized undercoating on mine, but rarely put it on the road in the winter.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #8 of 22 Old 02-03-2009, 06:14 PM
CrazyHorse6
1979 CJ7
Clean off all dirt, mud, rust, grease etc (be sure you do this thoroughly) and then treat any rust with POR's metal ready if you really want to do a good job. What I did was to then lay down a coat of "Rustoleum's Hammered Enamel" and let it dry for a few days. Then I hit it with the Herculiner and roll on pad and brush. I used the enamel first as a barrier just in case the rubber of the herculiner peeled or got cut and allowed moisture to seep in between it and the body. The herculiner was very easy to put on but pick up a cheap disposable rainsuit and long kitchen gloves and goggles. DONT GET IT ON YOUR SKIN.
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #9 of 22 Old 02-03-2009, 06:45 PM
certifiablejeep
Bicentennial Nickel
1976 CJ5
The duplicolor bedliner was a gallon kit at one of the local stores and was like 80 bucks... I bought a thing of disposable gloves as well. I went around with all the cracks and crevices with a cheapo paint brush and then rolled on a thin coat... I then did the same thing again thicker... it came out nice for not a whole lot of money and effort.
I then used herculiner on the inside of the tub... essentially making a bedliner sandwich... I coated the firewall(inside) and the inside top of the tub walls with black zerorust paint for a nice even finish all around... all black so it really stands out against the silver. I think the duplicolor went on better then the herc and I have been using herc for years.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #10 of 22 Old 02-03-2009, 06:59 PM Thread Starter
codyp8
1983 CJ7
this may be a dumb question but what about the seat holes on the inside of the tub does the liner not gunk the holes up or should i not worry about them
codyp8 is offline
post #11 of 22 Old 02-03-2009, 08:04 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
You can put golf tees in the holes, spray your coats, then just pull the tees. Had no problems at all, also some people used the rolable ear plugs that expands back to form.
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #12 of 22 Old 02-03-2009, 08:17 PM
mikeg576
mikeg576's Avatar
1945 CJ2A
i blasted mine, primering with eastwood rust encapsulator and rhino linering top and bottom of the floor.
45 2A 95 YJ
mikeg576 is offline
post #13 of 22 Old 02-03-2009, 08:19 PM
HeepToJeep
1982 CJ8
Regardless of what level of restoration you're doing I would definately NOT try to cut corners on the underbody simply because you can't see it..........it's the one area that's going to be more prone to stone and salt damage - which means rust! I'd clear it of ALL rust, coat it all in Rustbullet and then undercoat (3M or Zeibart) or Durabak it (smooth version of Herculiner). It'd be foolish to spend a ton of time and money restoring a vehicle only to have the floorboards rot out.
Wm
HeepToJeep is offline
post #14 of 22 Old 02-03-2009, 08:22 PM
mikeg576
mikeg576's Avatar
1945 CJ2A
Originally Posted by HeepToJeep View Post
Regardless of what level of restoration you're doing I would definately NOT try to cut corners on the underbody simply because you can't see it..........it's the one area that's going to be more prone to stone and salt damage - which means rust! I'd clear it of ALL rust, It'd be foolish to spend a ton of time and money restoring a vehicle only to have the floorboards rot out.
Wm
hell yea,
nothing worth doing is easy or fast.
45 2A 95 YJ
mikeg576 is offline
post #15 of 22 Old 02-03-2009, 09:14 PM
only in a jeep cj
My 86 was Z-bart undercoated by the original owner, BUT I've seen many old pics of new CJ's with the underside just painted the same as the body color.....not saying to do that, but can we confirm that was how they came?
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
Frame off restoration jmna Jeep CJ Forum 12 12-22-2008 03:00 PM
Frame on Restoration lou h Jeep CJ Forum 1 03-14-2008 12:32 PM
Frame restoration andresesquire Jeep CJ Forum 2 11-05-2007 07:54 PM
Frame off restoration 0lll077cj5 Jeep CJ Forum 8 07-16-2007 12:03 PM
Frame up restoration dblock16 Jeep CJ Forum 12 07-09-2007 09:08 AM
