Found this..... - JeepForum.com
 5Likes
  • 2 Post By stripperguy
  • 2 Post By cjoffroad
  • 1 Post By Renegade82
post #1 of 12 Old 06-09-2021, 05:14 PM Thread Starter
Trailhed1
Found this.....
Hi all, been lurking here for long time, great site with great info. Hoping someone can help me out and tell where this bolt belongs. Found in driveway after taking jeep out of garage.
1977 CJ7 AMC 304 3 speed
C3A276CE-986A-43B1-8A11-FA8F9F25ED2A.jpg   2B61B081-E103-4AF8-9D80-773230774C2C.jpg   03297BDB-9E65-426B-8596-5359C078ED9E.jpg   74B03F17-5D6B-4200-A020-20BE2442D096.jpg
Trailhed1 is offline
post #2 of 12 Old 06-09-2021, 06:35 PM
stripperguy
I'm not 100% positive, but I think it goes in a threaded hole...maybe.
I'm sure others with more experience will chime in shortly.
John Strenk and STJP like this.
1977 CJ5 is a CJ build ever really done?
2002 TJ gone
2005 TJ also gone
2005 LJ insurance wreck
stripperguy is offline
post #3 of 12 Old 06-09-2021, 07:43 PM
LowcountryTJ
Junior Member
LowcountryTJ's Avatar
Looks like a body bolt.
Check the fenders to body tub connection points/battery tray support bars/
front grill to the fenders connection points/radiator to front grill.
LowcountryTJ is offline
post #4 of 12 Old 06-09-2021, 08:58 PM
cjoffroad
cjoffroad's Avatar
1980 CJ7
Check your brake line support bracket on both sides of the frame.
John Strenk and Jim1611 like this.
cjoffroad is offline
post #5 of 12 Old 06-09-2021, 10:17 PM
Renegade82
Renegade82's Avatar
1982 CJ7
Check your fuel and brake line paths. It looks like a line clamp bolt/screw.
John Strenk likes this.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #6 of 12 Old 06-10-2021, 02:16 PM
Nor Cal CJ5
Nor Cal CJ5's Avatar
1972 CJ5
Looks like a catalytic cover bolt that holds the shield together, away from the cat.
1972 CJ5 304 V8, 3 speed manual trans
Nor Cal CJ5 is offline
post #7 of 12 Old 06-11-2021, 10:18 AM
baldfatdad
1984 CJ8
looks like a body bolt out of a japanese care
baldfatdad is offline
post #8 of 12 Old 06-11-2021, 04:12 PM Thread Starter
Trailhed1
Thanks for all the responses. I am beginning to think it might not be from the CJ. I have checked pretty much everywhere and nothing is missing. Will update further.
Thanks again everyone.
post #9 of 12 Old 06-11-2021, 05:43 PM
258
258's Avatar
Definitely a Jeep bolt. Check your fan shroud mounting bolts. There should be 4, 2 on each side; at bottom and 3/4 up. Check plastic water reservoir too! There’s nothing more nerve racking than finding a mystery bolt, lol. Good luck!
258 is offline
post #10 of 12 Old 06-11-2021, 09:18 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
My lawn mower uses the same kinda bolts to hold the covers over the spindle pulleys.
I have to remove (at least one side) to put the belt onto the pulley...The covers capture the belt in the pulley groove so that the belt stays in place
Maybe this is the case with your bolt.
----JEEPFELLER
JEEPFELLER is online now
post #11 of 12 Old 06-12-2021, 06:49 AM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
Dust shield on transmission bell housing?
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is online now
post #12 of 12 Old 06-12-2021, 10:20 AM
cj5ruger
cj5ruger's Avatar
Yes I would say it is definitely bolt more than likely threaded into the frame. Do you have a skid plate on your fuel tank?
cj5ruger is offline
