First time CJ owner, need a little help. - Page 2 - JeepForum.com
post #16 of 41 Old 02-23-2015, 06:52 PM
scoutboater
scoutboater's Avatar
1974 CJ5
Originally Posted by vdubbles24 View Post
I'm a rebuild rear drums. No E brake and super soft pedal. This jeep has power steering as well. Is that factory?
Also been looking for a throttle cable. Can't find nothin for early 70s
The power steering could be factory. I know on my 74, the pump its on the passenger side of the motor with the hoses running around the front of the motor to the box.
As far as the other parts, I'll ask about a rebuild kit and shoes for the rear, but the e-brake parts might be harder to find.
scoutboater is offline
post #17 of 41 Old 02-23-2015, 07:12 PM
scoutboater
1974 CJ5
Update:
I did some quick searching on the oriellys website and found the hardware kit, hoses, and drums in stock at my local store. The listed the shoes, but not in stock. I know they should be available if you are willing to wait a few days.
They also list a throttle cable in stock. It will probably be worth your time to talk to your local parts house for many of your needs.
post #18 of 41 Old 02-23-2015, 07:18 PM Thread Starter
vdubbles24
I never think about O'reilys. I just hit up autozone. I'm a stop by there when I get off in the morning.
The PO said it has a 4" lift and it has a 3" body lift. I personally hate body lifts so it's gettin tossed when I pull tub for a lil rust repair. 4" lift 33s should be fine right?
vdubbles24 is offline
post #19 of 41 Old 02-23-2015, 07:20 PM Thread Starter
vdubbles24
Oh and yes the ps pump is on passenger side of engine with hoses running under radiator.
Did these come with heaters? I have no heater core, dash controls, nothin. I'm not worried about heat I'm just curious.
post #20 of 41 Old 02-23-2015, 07:30 PM
scoutboater
1974 CJ5
Yes, they did. Mine was incomplete when I got it, but mostly there.
If you want, check out my build thread. There is a link in my signature.
post #21 of 41 Old 02-23-2015, 07:37 PM Thread Starter
vdubbles24
Will do.
Thank ya for ya help.
I just ordered cable, and brake parts "hardware kit and wheel cylinders" gotta call about shoes. Thanks again. Like I said I always forget about O'reilys.
post #22 of 41 Old 02-24-2015, 03:25 AM Thread Starter
vdubbles24
Locked it in and nothin, clean and regrease or discard and buy new? I know nothin about this style of hub.
post #23 of 41 Old 02-24-2015, 08:37 AM
scoutboater
1974 CJ5
How did you test it?
post #24 of 41 Old 02-24-2015, 10:37 AM
JeffreyCharles
JeffreyCharles's Avatar
1976 CJ5
As for the carb, to start with I'd rebuild the YF. It's *really* easy to do and doesn't cost much. I think I pay about $20 every year for a rebuild kit and the process takes maybe 20 minutes. That'll familiarize you with the process in general and what a carb looks like on the inside. Then, later, you might consider upgrading (though I like my YF just fine for the types of driving I do).
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #25 of 41 Old 02-24-2015, 05:01 PM Thread Starter
vdubbles24
Locked em in and drove it around yard. Front driver side would lock and spin but passenger side "in pic" did nothin.
I found the $20 carb kit. It's gonna be ordered. I think with a lil you tube assistance it should go ok on the rebuild.
post #26 of 41 Old 02-24-2015, 05:13 PM
scoutboater
1974 CJ5
That could just be an open differential. Unless the front axle is locked somehow, both wheels must be locked in to get either wheel to pull out spin.
post #27 of 41 Old 02-24-2015, 06:26 PM Thread Starter
vdubbles24
I feel like a idiot. My bad I shoulda known that. Anyhow I'm a pull both hubs and grease em well.
What's best sheet metal for repair panels? I've always used 16ga on other projects that be adequate enough for a old jeep?
post #28 of 41 Old 02-25-2015, 03:01 AM
Mike Romain
You only want a light coating of something like white lithium style grease in the hubs. Too much or heavy grease binds up in the cold.
Mike
Mike Romain is offline
post #29 of 41 Old 02-25-2015, 11:58 PM Thread Starter
vdubbles24
Stock rear axle is a Dana 20, what is the front?
post #30 of 41 Old 02-28-2015, 12:35 PM Thread Starter
vdubbles24
Bump
