Extremely rough suspension - JeepForum.com
 3Likes
post #1 of 16 Old 07-27-2021, 01:55 PM Thread Starter
sk8brdtoday1
Hi,
I was hoping for some advise. I have a 85 cj7 seems to be lifted 3-4” (I got it this way). The ride is extremely rough, I have aftermarket corbeau seat which are very padded and comfortable. And after a 5-10 minute ride my back is absolutely killing me from the rough ride and bumps. I brought it to my mechanic and he removed 1 leaf and it helped with the roughness a little bit. Also deflated the tires slightly. Is there a new suspension kit I can order or that anyone recommends for a “comfortable” ride?
Thanks!
sk8brdtoday1 is offline
post #2 of 16 Old 07-27-2021, 03:16 PM
81BatmanJeep
1981 CJ7
Always heard the Old Man Emu YJ conversion is the way to go. My plan for my 81 down the road is their 2.5 lift conversion.
81BatmanJeep is offline
post #3 of 16 Old 07-27-2021, 03:35 PM
Fourtrail
1974 CJ6
check the tightness of the bolts on the shackles and what kind of shocks do you have? Both can make for a harsh ride on a light weight vehicle like your Jeep.
JoonHoss likes this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 16 Old 07-27-2021, 04:06 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
As already suggested, shackle torque and shackle angle, shocks, and tire design / tire pressure can have great effect upon the pavement ride.
Whatcha got for each ?
My CJ-7 BDS lift and BDS shocks ride great with the 31x10.5 tires at 28 psi.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #5 of 16 Old 07-27-2021, 04:30 PM
Temujin
Junior Member
Temujin's Avatar
A friend of mine had the same problem with his cj-7. We use to take turns driving to work in it one week on and one week off. He bought it from a mechanic that did all sorts of things to it. 2 weeks a month we had stiff necks. He tried high back buckets that helped a little shocks ,tires leaf springs nothing helped. It was built for off road with a 351 ford motor. Finally he found 2 air cushion seats like in a tractor trailer. It made it drivable on the road. the seats worked well. I'm not sure what he got then out of.
1995 zj 4.0 242 6l 42re trans 242 transfer case 27 spline dana 30 front 35 rear
Temujin is offline
post #6 of 16 Old 07-27-2021, 06:34 PM Thread Starter
sk8brdtoday1
Thanks everyone for the responses. I’ve looked into the old man emu YJ conversion. I think that might be my choice for now. Does anyone have a part list they have used? Parts they really liked? Thanks!
post #7 of 16 Old 07-27-2021, 09:09 PM
Fourtrail
1974 CJ6
Everything you will ever want to know about doing the old man emu yj spring conversion.
https://www.jeepforum.com/forum/f8/o...stall-1245523/
post #8 of 16 Old 07-29-2021, 04:46 AM
keith460
keith460's Avatar
Here's my list of parts for the Old Man Emu suspension system: https://www.jeepforum.com/forum/f8/o...l#post41207683
1984 CJ-7 Renegade
keith460 is offline
post #9 of 16 Old 07-29-2021, 08:25 AM
Nick4320
Nick4320's Avatar
Heres a kit from Rocky-road outfitters, i highly recommend this company. while they say its a 3-3.5in lift i got my in march 2020 and when i measure it was a total of 2.75in lift now its sitting about 2.5in. The jeep rides pretty smooth handles great with 33s and 31s, just make sure to get the correct castor wedges.
Side note i also installed the HD rear shackle hangers and long travel shock mounts up front, Ive broken a spring plate that they supplied in the kit, contacted the company and the only question asked was which side and front or back.
https://www.rocky-road.com/cj-ome.html
Nick4320 is offline
post #10 of 16 Old 07-29-2021, 09:40 AM Thread Starter
sk8brdtoday1
Awesome, thanks everyone! I’m going to go with the emu conversion. One more question. What shocks do I buy? CJ or YJ shocks?
post #11 of 16 Old 07-29-2021, 09:40 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Your fix may be easier and cheaper than you think.
Do yourself a favor, pull the shocks and take it for a spin. Most lift kits run waaaaaay to stiff shocks.
Fldvr likes this.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #12 of 16 Old 07-29-2021, 09:56 AM Thread Starter
sk8brdtoday1
True, that’s a good thought. I’ll try that. And I run 33x10.5. Have 1” body spacer
post #13 of 16 Old 07-29-2021, 01:07 PM
Fldvr
Fldvr's Avatar
1974 CJ5
Absolutely this!! That was great advice!!
Now I’m on to the OME YJ Sping conversion.
**Word of warning**
The springs are backordered big time!!
Sent from my iPhone using Tapatalk Pro
Fldvr is offline
post #14 of 16 Old 07-30-2021, 12:44 AM
80cj
80cj's Avatar
1980 CJ5
Don't let anyone talk you into buying high pressure gas shocks. I have Doeschtech 3000 series hydraulics and they ride nice.
80cj is offline
post #15 of 16 Old 07-30-2021, 07:14 AM Thread Starter
sk8brdtoday1
Thanks for all the advice! And damn, didn’t know about the back order that sucks. A
