Exhaust gasket - which one? - JeepForum.com
post #1 of 3 Old 03-29-2020, 09:56 AM Thread Starter
GP_Pete
GP_Pete's Avatar
1934 CJ7
So getting ready to install new exhaust manifold.
Cleaned up some casting imperfections. While matching up gaskets I noticed 2 things:
1) the metallic Rugged ridge 3 piece gasket sent with the manifold (from Morris 4x4) matches the ports MUCH better...... but does not have a center ‘piece’ on the middle two ports
2) the Edelbrock gasket is one long piece, and does not fit the ports well. Probably cuts into the openings about 1/8 inch all around - worse around the points of the doglegs.
Thoughts on which I should use?
Sent from my iPhone using Tapatalk
AMC 360
GP_Pete is offline
post #2 of 3 Old 03-29-2020, 10:30 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I used the Sealed Power exhaust gaskets from Summit racing. It was a multi-piece set. The center double port gasket did not have the middle ridge, but the gasket matched the exhaust port pretty well.
Matt
Matt1981CJ7 is offline
post #3 of 3 Old 03-29-2020, 10:45 AM Thread Starter
GP_Pete
GP_Pete's Avatar
1934 CJ7
Thanks matt. Think im going with the three piece one. Gonna return the edelbrock. They probably reduce the port size by 5-10%.
AMC 360
GP_Pete is offline
