Engine Problem - Page 4 - JeepForum.com
 13Likes
post #46 of 74 Old 07-24-2020, 05:25 PM
Dryseals
1980 CJ7
I agree, the 38.
32/36 is a progressive carb and was designed for fuel economy on small motors. The 258 is nothing more than a glorified tractor motor, it will last forever and keep going but its never going to be a fuel economy lover. Give it what it wants. Tons of folks on here use it and they all seem to be very happy with it. Its what I am going with when I change out the old cast iron intake. I've heard nothing but good things about this guy
uptillnow likes this.
Dryseals is offline
post #47 of 74 Old 07-25-2020, 08:51 AM Thread Starter
Alabamacj71981
Alabamacj71981's Avatar
So I read a bunch of threads and looks like people switch to the Weber 38 from the Weber 32/36 but also all you guys recommend it. Thanks for the coaching.
Follow up:
(1) I replaced some more vacuum hoses still problem persists
(2) replaced ignition coil still problem persists. It was really old and I was struggling to get a good resistance reading on one of the two readings. I hoped that was it.
(3) replaced rear main seal and oil pan gasket thereby allowing me to move away (when replacing engine oil) from the Shell Rotella back to normal engine oil - had made the switch right before this happened but still problem persists.
(4) replaced the the distributor cap and button still problem persists (had already replaced spark plugs and checked plug wires) still problem persists.
(5) new air filter
Looks like it has to be the carb. Outside of an electrical issue, can you imagine anything else I should check? Otherwise, looks like I have to pull the trigger on the 38 carburetor.
Alabamacj71981 is offline
post #48 of 74 Old 07-25-2020, 09:05 AM
John Strenk
John Strenk's Avatar
1976 CJ5
If you go with the Weber, that air cleaner housing on the Holley is better than what comes with the Weber.
an adapter like this will work since you don't have power brakes.
But if you are thinking about power brakes in the future. You might need to go with a stock air cleaner housing.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #49 of 74 Old 07-27-2020, 02:08 PM
ccoyle71
Call Tom at Redline if you're going to order a Weber 38. And - whatever you do - DON'T get the 32/26. That's what I tinkered with for 2 years before buying a 38, and my Jeep has never run better. I know you mention putting a new coil and distributor cap on already - but the combination of an an HEI distributor and the Weber 38 solved 99% of issues for me: Sputtering at various speeds, idle misses, smoke, fuel economy, etc, etc.....the list could go on and on. Best money I've spent on my CJ since I've owned it. Good luck, keep us posted
ccoyle71 is offline
post #50 of 74 Old 07-27-2020, 08:31 PM Thread Starter
Alabamacj71981
Thanks. I’ll order from Redline. Looks like a good price. I’ll also get that air filter adapter mentioned above. I like the look of the 9 inch old school design. Thanks guys.
post #51 of 74 Old 08-02-2020, 08:29 PM Thread Starter
Alabamacj71981
Bought my Weber 38 and air filter adapter!
Dryseals likes this.
post #52 of 74 Old 08-03-2020, 10:43 AM
ccoyle71
Make sure and check the baseline settings for the speed screw and verify the enriching holes aren't exposed. Do this on the bench, BEFORE bolting it on so you know exactly where you are starting out. Good luck - and make sure and report back!
ccoyle71 is offline
post #53 of 74 Old 08-07-2020, 07:16 PM Thread Starter
Alabamacj71981
So just got my Carburetor and already hit a snag. Dope. I followed the instructions up to the point where I hit four stripped screws from PO. See pics of above and below pic. Lovely surprise.
I think I should use flame and PB Blaster but since I don’t want to use fire around gasoline sources... I should remove the intake manifold.
9014ACC1-55E3-477D-BED8-517AF6E85AA0_1596849195807.jpg   1014F41A-D0ED-4B27-A7A5-6C05FA94E045_1596849347688.jpg
post #54 of 74 Old 08-08-2020, 02:10 PM
oldschool74cj5
hello
when you say striped screws are you talking about the hex inside the screw is stripped out. if so you might try using a multispline easy out by hanson.
oldschool
oldschool74cj5 is offline
post #55 of 74 Old 08-08-2020, 04:39 PM Thread Starter
Alabamacj71981
Well, a neighbor saw me working and then let Darsey know. Darsey is only the coolest guy on the block. He is about 70 years old and restores 1940’s Harleys. You’ll see him ride around the neighborhood on his restorations. He’s a super laid back cool cat.
He came over and basically gave me a clinic on how to remove seized bolts. In the end the bolts are removed. He opened up my old Holley arb and showed me gunk in the bowl. He recommends that I clean or replace my original gas tank next, before the new carb install.
I just replaced my dash and so have to wait until next month to abide by the family rules on my Jeep spending.😬
Im going to use this time to clean and paint my intake and exhaust manifolds.
post #56 of 74 Old 08-08-2020, 07:46 PM
oldschool74cj5
hello
since you have the intake off. i would reseal the intake. if you buy the felpro intake exhaust gasket set it comes with the o-ring and gasket for the electric heater. i also retorqued my intake and exhaust manifold after i drove it a few times.
oldschool
post #57 of 74 Old 08-09-2020, 12:45 PM Thread Starter
Alabamacj71981
Originally Posted by oldschool74cj5 View Post
hello
oldschool
Sounds good. I saw a guy on YouTube soak his exhaust manifold in a vinegar and salt bath. They came out beautifully. Probably will try that.
post #58 of 74 Old 08-09-2020, 07:16 PM
gutthans
gutthans's Avatar
The 'acid dip' will leave a nice finish...but it will oxidize rapidly unless you coat it with something. There are several 'clear' engine coatings that can be rattle-canned and will hold up well.
gutthans is offline
post #59 of 74 Old 08-10-2020, 03:36 PM Thread Starter
Alabamacj71981
hello
oldschool
Thanks for the heads up. I’ll look for it. I did a Felpro on the oil pan and it was a super nice gasket with the easy install screws.
post #60 of 74 Old 08-10-2020, 04:34 PM
uptillnow
uptillnow's Avatar
I'm going to use this time to clean and paint my intake and exhaust manifolds.
I was looking at your first picture and those threads look ok, must be "photo-Shopped"
The second picture looks like you struck "gold", but probably a tank full of rust. New/Clean the tank, replace some rubber hose, new filters, good to go.
The third picture looks like a lot of work on the dash, looking good!
Where did you buy your Weber 38-DGES?
UTN
uptillnow is offline
