Engine Paint - JeepForum.com
post #1 of 8 Old 08-11-2020, 06:26 PM Thread Starter
c82cj
c82cj's Avatar
1982 CJ7
Engine Paint
I just realized after spraying that my 2 very light coats of primer were not engine primer. Thanks to AutoZone putting is in between the high temp paint. Question - it says up to 200 and I have already put real engine paint on top. Will I be ok? Not sure what else I can do rn.
No Top No Doors please
c82cj is offline
post #2 of 8 Old 08-11-2020, 07:30 PM
Nor Cal CJ5
Nor Cal CJ5's Avatar
1972 CJ5
If it is a show jeep, then strip it and repaint it.
Really, I think you will be ok...
1972 CJ5 304 V8, 3 speed manual trans
Nor Cal CJ5 is offline
post #3 of 8 Old 08-12-2020, 07:41 AM
cglax6
1976 CJ5
What's the status of the engine? Is it still in the vehicle? Is it just the block, or is it all put together?
If it's just the block, and you have the desire to do so, strip it and start over. If not, it's going to be too much of a hassle. Leave it go and drive it!
cglax6 is offline
post #4 of 8 Old 08-12-2020, 09:44 AM Thread Starter
c82cj
c82cj's Avatar
1982 CJ7
It is still in the vehicle. While I am getting the head worked on. Hopefully it will hold because the paint look really good so far!!
c82cj is offline
post #5 of 8 Old 08-12-2020, 11:09 AM
Nor Cal CJ5
1972 CJ5
Post up some pics!!!
post #6 of 8 Old 08-12-2020, 12:22 PM Thread Starter
c82cj
c82cj's Avatar
1982 CJ7
Wink
I absolutely will. I was waiting for have the completed engine put together before posting. If you think I should post a few now I can do that but the head isn't on yet.
c82cj is offline
post #7 of 8 Old 08-12-2020, 04:38 PM
Dryseals
1980 CJ7
I did a SBC 350 once with rattle can primer and then Shot it with Dupont Chromabase...kind of funny, I had several pint cans of the Chroma laying around, mixed this metalic blue with a red and added a touch of white. It came out looking like Barney purple and thus the name stuck for the entire truck. That was 25 years ago, truck is gone but I still have the motor and the paint is till holding up through thousands of heat cycles.
Dryseals is offline
post #8 of 8 Old 08-13-2020, 02:40 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
200 Fahranheit or Celcius?
The exterior of the block gets up to around the coolant temperature, 240 Fahrenheit / 120Celcius.
Headers / manifolds will get up to a lot higher and the block next to the manifolds will also get a lot hotter, but more than an inch away it will not get hotter than 240/120.
Leaving a margin of error, I would just go with it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
