engine bolt size - JeepForum.com
post #1 of 7 Old 03-03-2007, 05:10 PM Thread Starter
Indy
Indy's Avatar
engine bolt size
I'm finally getting my 304 off of the wooden pallet its living on and up onto an engine stand. I don't have any bolts to mount through into the block though and don't know which size to get when I hit the hardware store. If anyone knows the length and size I would appreciate the info.
I'm the only gay eskimo.
Indy is offline
post #2 of 7 Old 03-03-2007, 05:16 PM
Bulldog Dave
1975 CJ5
Bolt size
They are either 3/8"x16 x 4" or 7/16"x14x4". I also have some washers handy to take up any slack.
Bulldog Dave
1975 CJ-5, AMC 360, T-18 w/6.32, D300, 4.56's, D30 w/Lock-rite, D44 w/spool & FF, 33x12.50 MTRs, full cage, OBA, PPW, and a few other mods.
Bulldog Dave is offline
post #3 of 7 Old 03-04-2007, 07:57 AM
jadams68
jadams68's Avatar
2014 JK Wrangler
I used a combination of 3/8x16x3.5" and 7/16x16x3.5". I used all grade 8 hardware and used a few washers to get the proper tightness and fit.
'14 Rubicon Unlimited, AEV 3.5" DualSport, AEV Front and Rear Bumper, Warn 9.5cti, 35" BFG M/Ts
jadams68 is offline
post #4 of 7 Old 03-05-2007, 10:01 AM Thread Starter
Indy
Indy's Avatar
3/8 x 16 was the winner, but 3.5 and 4" bolts were waaaay longer than my stand needed, but nothing an extra lug nut and a few washers couldn't eat up. I bought standard bolts, if I had been thinking I would have gotten at least grade 5. That 304 is crazy heavy.
Indy is offline
post #5 of 7 Old 03-05-2007, 10:21 AM
fuzz401
1978 CJ7
7/16x14 for the bottom bolts on each side all the rest are 3/8x16
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #6 of 7 Old 03-05-2007, 02:46 PM
biozombie
If someone used long 3/8" bolts for the two side bolts (three & nine 'o clock positions) during the final assembly of the motor & trans, would this cause an alignment issue with the tranny input shaft ?
biozombie is offline
post #7 of 7 Old 03-05-2007, 03:38 PM
fuzz401
1978 CJ7
there should be 2 sleaves that line up the bell housing to the motor on the 3 & 9 o'clock bolts that take 7/16-14 bolts
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
need bolt size for v8 motor mount bolt to frame rcgkaw Jeep CJ Forum 3 08-25-2009 09:16 PM
SOMEBODY has to know this OEM bolt size... darowden Jeep CJ Forum 11 07-06-2009 03:34 PM
Bolt size help!!!!! hugedodge2000 Jeep CJ Forum 1 05-30-2009 09:33 PM
what size are the torx bolts? (the actual bolt, not the "t" size) NJCJ7 Jeep CJ Forum 5 11-09-2003 09:48 PM
Bolt size TonyTJ Jeep CJ Forum 4 08-15-2003 09:09 AM
