Engine angle question - JeepForum.com
post #1 of 7 Old 09-27-2008, 07:27 PM Thread Starter
OSUAV8R
I finally got the transmission back in my jeep, but with the tranny mount resting on the skid plate the engine seems to be slanted down in the back (higher inthe front) How much is to much, I was thinking about shimming up the tranny to make the engine sit more level... I am sure I can do it, but the real question is .... how much rear tilt is to much?
Thanks
Nathan
OSUAV8R is offline
post #2 of 7 Old 09-27-2008, 07:43 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I wouldn't be concerned until I started getting more than say 5-6 degrees slope. As you tilt the rear of the drivetrain down, the front tilts up. That can cause front ujoint bind if you have alot of lift or a flexy front suspension.
BESRK is offline
post #3 of 7 Old 09-27-2008, 08:01 PM Thread Starter
OSUAV8R
I am more concerned with oli and coolent hot spots because of the angle
Thanks
Nathan
OSUAV8R is offline
post #4 of 7 Old 09-27-2008, 08:46 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've put an angle finder on several "stock" setups with 4-5 degrees of drivetrain slope..
BESRK is offline
post #5 of 7 Old 09-27-2008, 09:58 PM
JeepHammer
1973 CJ5
BESRK is correct.
If you are worried, take the carb off and put a level on the carb manifold flange.
When it's level both directions, the engine is installed at the correct angle, around 2 to 5 degrees downward slope to the tail shaft...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #6 of 7 Old 09-27-2008, 10:05 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
My 5.0L swap is right at 3* rear down, with no skidplate drop.
"In the end...It's all Hack."
HackFabrication is offline
post #7 of 7 Old 09-27-2008, 11:20 PM Thread Starter
OSUAV8R
Thanks guys, I have to measure it... but it seems more then 5.. the Matkins frame was 11/16 of an inch narrower on the inside.. so the main mounts are closer together and therefor the engine sits higher
OSUAV8R is offline
pinion angle question!! please help burtonboard180 Jeep CJ Forum 8 01-19-2010 07:05 PM
New lift question - shackle angle question *Thunder Jeep CJ Forum 2 10-09-2009 09:53 AM
Lift experts - driveshaft angle vs engine angle imtheant Jeep CJ Forum 14 05-26-2009 10:08 PM
laid back... engine angle... T-18 and 4" lift. certifiablejeep Jeep CJ Forum 16 05-05-2008 04:51 AM
Caster angle question jode Jeep CJ Forum 8 01-23-2007 05:41 PM
