EGR Valve hookup - JeepForum.com
post #1 of 15 Old 09-05-2019, 03:22 PM Thread Starter
CJPondScum
1983 CJ7
EGR Valve hookup
Hello all!
I recently installed a new radiator, fan shroud, clutch and fan... Still running between 200 and 220 around town. I worry that I will get even hotter rock crawling. My EGR valve is capped off as you can see in the photo. I think I'm going to swap in a new one and hook it back up. I read that having it not hooked up could cause some heat issues.
Any idea where I route the EGR valve too without having all of the other emission systems in?
AMC 360 motor
Thanks Kevin
Kevin
1983 CJ7 - PondScum
360 TH400
35's 4:56
CJPondScum is offline
post #2 of 15 Old 09-05-2019, 04:18 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Well it should go to a CTO and then the ported vacuum port on the carb so it doesn't open up when the engine is cold.
You need the ported vacuum so it's closed at idle otherwise it will mess with the idle. that way it also closes at full throttle so it doesn't rob any power.
But I wonder if it will help the over heating you are seeing. It might be you could be doing a lot of idling rock crawling
An EGR will keep the cylinder temps down but those temps are relatively high (still hot) and might help if you are experiencing knock or ping but otherwise might not help much.
You might of been better off with an electric fan that can still pull air through quickly the radiator at slow speeds.
ave you checked your thermostat? Accuracy of your gauge?
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #3 of 15 Old 09-06-2019, 12:11 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The temp rise found by disconnecting the EGR is negligible. Your issue is elsewhere.
Have you verified your temp using an IR gun?
Did you replace the thermostat? Is it opening all the way?
A radiator cap that won't hold pressure will cause overheating.
Same with a collapsed lower radiator hose.
Anything blocking the radiator (winch, lights, bug screens, etc.)?
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #4 of 15 Old 09-06-2019, 10:04 AM Thread Starter
CJPondScum
1983 CJ7
I replaced the thermostat and its opening. Verified temp with an IR gun and it seems to mostly stay at 210 but will creep to 220 in traffic. I will check the hoses again but they don't appear to be collapsing. Maybe I need to do a full coolant flush and just replace the hoses. Nothing blocking the radiator.
I don't have a hole drilled in the Thermostat. I have read a lot of people do that.
I hate cooling system issues lol. Seems to be soooo many things it can be. Is my clutch and fan working properly, is the waterpump bad... ugh.
Kevin
1983 CJ7 - PondScum
360 TH400
35's 4:56
post #5 of 15 Old 09-06-2019, 11:32 AM
John Strenk
1976 CJ5
If you have an IR gun you can probably measure the input and output temperature of the radiator.
I would have to contemplate the effect of low water flow vs. low air flow to give an answer.
What temp thermostat do you have in there?
Any bubbles in the tank when running
post #6 of 15 Old 09-09-2019, 10:28 AM Thread Starter
CJPondScum
1983 CJ7
I have a 180 thermostat in there. No bubbles. I did a full system flush last night. The radiator and block weren't terrible and flushed green coolant.... but the pic attached is what came out of the heater core. Hoping this helps keep me between 190 and 200.
Kevin
Kevin
1983 CJ7 - PondScum
360 TH400
35's 4:56
post #7 of 15 Old 09-11-2019, 01:32 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
The hole in the thermostat helped on my L head but that is peculiar to that engine.
If your water temperature is always at least 30 degrees above the thermostat range, it is not good.
Have you checked the water pump?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 15 Old 09-11-2019, 10:21 AM Thread Starter
CJPondScum
1983 CJ7
Haven't touched the water pump yet, will have to figure that out.
Any idea what the different temps are on this gauge? I thought I had it figured out but maybe not. I definitely need an upgrade here.
Kevin
1983 CJ7 - PondScum
360 TH400
35's 4:56
post #9 of 15 Old 09-11-2019, 11:08 AM
John Strenk
1976 CJ5
Celcius and Farenheit
That's why the C and F are different colors at the bottom of the gauge so you know which scale is which.
post #10 of 15 Old 09-11-2019, 11:44 AM Thread Starter
CJPondScum
1983 CJ7
So would you say the temp in the pic is about 210 F?
Kevin
1983 CJ7 - PondScum
360 TH400
35's 4:56
post #11 of 15 Old 09-11-2019, 12:02 PM
John Strenk
1976 CJ5
Some where around there. Probably closer to 200 F
it's less than 100 C which is 212 F.
That scale is not linear so it's hard to say exactly.
post #12 of 15 Old 09-11-2019, 01:34 PM
mc190
your well under 200deg f. your well in a "safe" temp. But changing out the water pump fresh coolant and a new thermostat and hoses will not hurt, especially if you have no idea how old the old stuff is. Probably do that under $100.
mc190 is offline
post #13 of 15 Old 09-11-2019, 11:53 PM
jeepdaddy2000
1971 CJ5
Do your self a favor and ditch the cheap gauge and replace it with a quality gauge, such as a Stuart Warner.
Thomas Payne
post #14 of 15 Old 09-12-2019, 01:19 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
If that is what you are running at then,given the vagaries of the gauges, you may be running at thermostat temperature most of the time.
Good clean out and fresh coolant may fix you up.
post #15 of 15 Old 09-12-2019, 10:20 AM Thread Starter
CJPondScum
1983 CJ7
Thanks all! Ordering a new gauge now!
Kevin
1983 CJ7 - PondScum
360 TH400
35's 4:56
