EFI Conversion Kit - JeepForum.com
 28Likes
post #1 of 39 Old 08-22-2019, 06:11 PM Thread Starter
jdbourgeacq
EFI Conversion Kit
Does anyone have any experience with conversion from carburetor to EFI for a CJ7 6 cylinder 5 speed? Trying to educate myself before I spend the money. Any recommendations, for or against, would be greatly appreciated. Thanks!
Sent from my iPhone using Tapatalk
jdbourgeacq is offline
post #2 of 39 Old 08-22-2019, 06:30 PM
jlkeener
1980 CJ5
Don't have the six cylinder but I did the Howell conversion to my 1980 304 and couldn't be happier. Fixed all my stalling and idling issues. Installation wasn't that hard as all the harness/fuses are in the harness Howell provides. IMHO it was money well spent.
jdbourgeacq likes this.
jlkeener is offline
post #3 of 39 Old 08-22-2019, 07:47 PM
jay-h
I did the Howell on my YJ. The best improvement of any mods I've done.
The instructions are a little disorganized, but you'll get through it. And depending on where you live, they have an EPA approved version.
CrashOdle and jdbourgeacq like this.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #4 of 39 Old 08-22-2019, 07:56 PM
Rondawg80
1980 CJ5
I did the Howell on my 1980 CJ5 258 six. WORTH EVERY PENNY! I am in CA. and my smog numbers are nearly nonexistent. Excellent throttle response and idles smooth.
Rondawg80 is offline
post #5 of 39 Old 08-22-2019, 08:43 PM
StoneTower
If you don't need it for smog (emission) reasons, you might want to look at some of the newer EFI kits. If you are ever thinking of installing a SBC the other kits would trade over. Some of the newer kits have setting for various engines. The Howell is 30+ year old technology but some of the kits are approved for California emissions on Jeep vehicles. There are cheaper more modern solutions if you don't need it to pass emissions.
StoneTower is offline
post #6 of 39 Old 08-22-2019, 09:21 PM
Anywherebuthere
Did a Howell on my '78 258. Old tech but does the job. I would also suggest, although not necessary, that you swap to a cam that is designed for fuel injection. Noticed a difference when I swapped cams in mine. Used a Comp Cams 68-232-4 myself. Of course that also requires that you verify the valve train geometry if you switch cams but it's quick work on a 258. I needed different pushrods with that cam.
Sent from my Pixel 2 XL using Tapatalk
Anywherebuthere is offline
post #7 of 39 Old 08-22-2019, 11:13 PM
thekojak
I did the affordable fuel injection kit on mine. It was the best thousand dollars I ever spent. I think they offer spark and fuel control with their new kits.
Sent from my SM-N950U using Tapatalk
thekojak is offline
post #8 of 39 Old 08-22-2019, 11:35 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
It started with throttle body Injection, a simple injector in what looked like a carb. If you could fit an oxygen sensor in the exhaust, a crankshaft position senor, a stronger fuel pump, high pressure hose, controller, you were good to go. reliable. This is what Howell sells.
Of course Mopar have a much better system, on the 4.0HO, that has an injector for each cylinder. better mixture. You can with a bit of work get the entire Mopar injection system to work on the 258. Reliable.
There are plenty of newer choices, the Holley Sniper EFI has a version for Jeep 258s which looks a bit like a BBD carb and comes in silver, black and gold!!!! Still looks like TBI to me.
If you were a genius level you could use a 4.0HO manifold and injectors and pump etc and mix it up with a Megasquirt controller to make it fully programmable. I have been looking at this for some time, just don't think i will get the full benefits on a lumbering 258.
John Strenk and jdbourgeacq like this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #9 of 39 Old 08-23-2019, 12:03 AM
AMCJeeps
I put the Howell throttle body kit on my 84 CJ with the 258. Best $ I've spent on the CJ. transformed the vehicle. Much much better than the damn carb.Not only runs better, but you get to toss out yards of vacuum hoses, wires and worthless smog equipment.
84 CJ7 Renegade
87 XJ Laredo
97 Toyota Tacoma 4x4
AMCJeeps is offline
post #10 of 39 Old 08-23-2019, 12:32 AM
StoneTower
Fitech
https://www.summitracing.com/search/...cending&page=3
I think you can get the Fitech for less money and it is a modern EFI system. They even make a 2 barrel system but I would use a carb adapter and use a 4 barrel unit in case I wanted to throw a SBC in some day.
post #11 of 39 Old 08-23-2019, 10:58 AM
CrashOdle
CrashOdle's Avatar
1981 CJ7
Best Money Spent
81 CJ7 with the 258, did the Howell conversion. Best money spent! Starts perfect every time, and runs beautiful. Also a Ca jeep, smog hasn't been an issue.
81 CJ7 258 Howell TBI/T999/Dana 300/Dana 44s locked Methods and 35" MTRs
06 LJ on 44s Full Traction LA w/ Kings rolling 17" Racelines and 37" Toyo muds, Genright armor up, under and around
"but babe, it's a safety modification...."
CrashOdle is offline
post #12 of 39 Old 08-23-2019, 12:59 PM Thread Starter
jdbourgeacq
Thatís so awesome info! I appreciate it! Thanks, yíall! So it sounds like Howell and Fitech are the favorites to go to. Any models in particular you might recommend?
Also, CJs are pretty straight forward simple mechanics (even when the Weber Carbs act up). So Iím curious, in the event that thereís a massive magnetic attack, would introducing the electronics wipe out any chance that the Jeep might start (sorry for my nerdiness, lol)?
Anyway, all your inputs and info are so helpful, thanks!
post #13 of 39 Old 08-23-2019, 07:47 PM
trailhead2004
trailhead2004's Avatar
1980 CJ7
EMP will kill any EFI system. Itís the electronic part thatís the problem. Unless of course you want to spend large government sums of money to harden the system. 🤪
trailhead2004 is offline
post #14 of 39 Old 08-23-2019, 09:18 PM Thread Starter
jdbourgeacq
post #15 of 39 Old 08-24-2019, 01:09 PM
tchimmerroks
1983 CJ5
I did the Howell, tbi kit on an '81 CJ5, 4.2L. I also had an Erson, RV cam in the engine, and HEI distributor. It ran, and performed fantastic.
tchimmerroks is offline
