EFI on a 360 WITH a TF999 - JeepForum.com
post #1 of 10 Old 09-09-2021, 01:04 PM Thread Starter
scottyDive
I probably need a new carb so am wondering if this is the time to leap to EFI.
Is there a bolt on that works with the Torque Flight 999 tranny? Anyone do this with theirs ? Would love feedback and part # if possible. Thanks
Sent from my SM-G960U using Tapatalk
Scott
86 CJ7 Laredo
84 CJ7 Renegade
70 Jeepster
scottyDive is offline
post #2 of 10 Old 09-09-2021, 08:00 PM
RiverandSand
1980 CJ5
EFI is always a good choice, the auto trans you have isn't computer controlled, any of the current EFI kits would work. I'm in the process of installing a Holley Sniper kit on mine, the Holley kits have a number of choices you can choose from.
RiverandSand is offline
post #3 of 10 Old 09-10-2021, 05:31 AM
CJKevin1978
Subscribed: I am slso considering this upgrade once I finally get my suspension completely sorted out. Debating 2Bv4B, I don't expect this engine to every be a fire-breathing monster but also don't want its TB/carb to be the limiter for its power.
CJKevin1978 is offline
post #4 of 10 Old 09-10-2021, 06:23 AM
cglax6
1976 CJ5
As stated above, you won't have an issue since the TF999 isn't computer controlled.
I have a Holley Sniper on mine with all the Hyperspark goodies to have the ECU control timing. I love it. If you're bad at reading/following instructions, then EFI might not be for you...at least with the Sniper, if you don't follow the directions, you'll be chasing gremlins for as long as you own it. If you do it right, you'll be just fine.
If you go EFI, do yourself a favor and get an in-tank pump. It's tough to use an in-line pump and not have it pull from the fuel tank because how low it sits relative to the frame. If the pump is pulling fuel from the tank, it's going to struggle and fail early...those pumps are designed to push fuel, so they need to be lower than your fuel tank.
I also bought all of my stuff through EFISystemPro. They're very knowledgeable and they answered all of my questions before I bought anything. They also provide 2 years of troubleshooting and tuning for free if you buy from them.
If you have any Sniper specific questions, feel free to PM me.
cglax6 is offline
post #5 of 10 Old 09-10-2021, 10:11 AM
RiverandSand
1980 CJ5
I agree with in tank pump, I also bought the sniper replacement tank but it isn't any different than the stock CJ 15 gal tank, no extra ports for a return line. It is galvanized and painted which most of the others aren't.
The in tank pump has an internal pressure regulator set to 58 psi, so I am not going to run a return line which will save some headaches with the install.
post #6 of 10 Old 09-10-2021, 03:36 PM
CSP
If the question of compatibility is centered around the throttle valve linkage, Lokar makes a cable you can use.
CSP is offline
post #7 of 10 Old 09-10-2021, 04:20 PM
whollsee
1982 CJ7
Lokar throttle and kick down cable kit for tf999 on my Fitech EFI
When ever I hear the word 'Jeep' I reach for my wallet.
whollsee is offline
post #8 of 10 Old 09-11-2021, 10:39 AM
Axhammer
Axhammer's Avatar
I used a Lokar kickdown cable kit on my OEM style MPFI with a BBK throttle body when I swapped to a 4.0 based inline six (4.7 stroker).
The Lokar cable has worked out very nice, I made a couple adjustments to get my OEM TF999 transmission shifting where I want it to shift. I used a spring to hold the transmission arm against the stop, and then removed all slack at the TB end for a starting point, and then fine tuned it from there.
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is online now
post #9 of 10 Old 09-13-2021, 08:13 PM Thread Starter
scottyDive
Thanks for the good info...so a minimum of $1500 in parts alone. Will do more research but appreciate any insight and experience anyone can share
Scott
86 CJ7 Laredo
84 CJ7 Renegade
70 Jeepster
post #10 of 10 Old 09-14-2021, 04:21 PM
CSP
How about some idea of which EFI setups you're considering. You know, narrow down the ambiguity a bit.
CSP is offline
