JeepForum.com (https://www.jeepforum.com/forum/)
-   Jeep CJ Forum (https://www.jeepforum.com/forum/f8/)
-   -   Ebay HEI distributor still bad? (https://www.jeepforum.com/forum/f8/ebay-hei-distributor-still-bad-4313511/)
Jeepdvm 06-20-2018 08:23 PM
I bought a HEI distributor off eBay last year before I knew as much as I do now. I know they had a problem with hardened gears, especially with the V8’s. I have 258. Are people still experiencing the same cam gear issues with these on a 258? How can I tell if my HEI is damaging my engine? I’ve probably put less then 200 miles on engine since installing the distributor.
uptillnow 06-21-2018 12:20 PM
Originally Posted by Jeepdvm (Post 40253847)
I bought a HEI distributor off eBay last year before I knew as much as I do now. I know they had a problem with hardened gears, especially with the V8ís. I have 258. Are people still experiencing the same cam gear issues with these on a 258? How can I tell if my HEI is damaging my engine? Iíve probably put less then 200 miles on engine since installing the distributor.
There are many companies that sell the H.E.I. for the Jeep six cyl. Some are better than others.
The gear issue has pretty much been fixed, although it is metal to metal and wears.
If you are concerned about this possible wear, pull out your distributor and visually inspect (look at with authority) the wear on the gears. 200 miles is enough to see if you are going to fail.
UTN
Matt1981CJ7 06-21-2018 12:41 PM
I think the hardened gear issue is more prevalent with the V8 engines because the cam gear is a separate part and is often softer steel than the distributor gear. It's usually best to order a matching set of gears for the V8.
On a 258, the cam gear is machined into the cam, so it's already hardened steel. Therefore, it's not as susceptible to the wear issue.
Matt
The time now is 03:05 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
