DUI on 258, Port vs Manifold Vac Carter BBD. - Page 2 - JeepForum.com
 12Likes
post #16 of 23 Old 09-24-2021, 11:15 AM Thread Starter
PrincessJ
PrincessJ's Avatar
1983 CJ7
Originally Posted by devildog80 View Post
PrincessJ.....this is for you
Thats funny.... its kinda like when I was installing my live wires my friend caught a pic of me before an outing
devildog80 likes this.
"Simple is Reliable"
Military service: March 2007-(I will fill this out with im done.)
PrincessJ is offline
post #17 of 23 Old 09-24-2021, 11:53 AM
uptillnow
uptillnow's Avatar
Originally Posted by Matt1981CJ7 View Post
In my experience, connecting the vacuum advance to manifold vacuum, after setting initial timing, should only increase the idle about 150 RPM on a 258. It's odd that yours increases 300 RPM.
I'd try UpTillNow's recommendation to retard the vacuum advance a little.
Matt
I have found adjusting the advance canister when manifold vacuum is applied to around 15 degrees more advance from the initial 10-12 BTDC is all that is needed for 700 RPM idle speed.
I too have found the RPM increase is roughly only 150 RPM's on a 258.
So, with the initial at 10-12 BTDC, then the advance canister adjusted to 15 degrees increase when manifold vacuum is applied, still increases the idle more than 150 RPM's there may be a vacuum leak as Shawn suggested. (?)
UTN
uptillnow is offline
post #18 of 23 Old 09-25-2021, 11:32 AM
Shawn Watson
Shawn Watson's Avatar
1983 CJ7
The OEM BBD on my '83 acted much the same way yours appears to. It had an 800ish idle with the speed screw all the way out, there was a trough in the plastic, stepped, fast-idle cam from the screw and even the metering rods had a flat worn in them from nearly 30 years of service.
You may want to move your attention to that. Is your PCV good to go?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
Shawn Watson is offline
post #19 of 23 Old 09-26-2021, 11:18 AM Thread Starter
PrincessJ
PrincessJ's Avatar
1983 CJ7
Shawn
PCV is functioning as it should, I will dig into it at the end of next week.
post #20 of 23 Old 10-06-2021, 03:41 PM Thread Starter
PrincessJ
PrincessJ's Avatar
1983 CJ7
Carb was finger loose. It's now idling at 700 at 180 degrees after a 7/16 wrench to tighten it. Confirmed timing and it tests sat.
Matt1981CJ7 likes this.
post #21 of 23 Old 10-06-2021, 04:01 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Nice work, Princess!
PrincessJ likes this.
Matt1981CJ7 is offline
post #22 of 23 Old 10-06-2021, 05:33 PM
Shawn Watson
1983 CJ7
I had a feeling you had a sneaky air leak hiding out somewhere. Glad you found it.
Shawn
Matt1981CJ7 and PrincessJ like this.
post #23 of 23 Old 10-06-2021, 07:08 PM Thread Starter
PrincessJ
PrincessJ's Avatar
1983 CJ7
The starting fluid test found it quickly
JEEPFELLER likes this.
