This doesnt look right? - JeepForum.com
post #1 of 12 Old 08-19-2011, 06:33 PM Thread Starter
Jwfinley
1978 CJ7
So I just put a 4" lift on my 78 cj7 and these shackles don't look right. http://
Also the bolt that connects the back of the front leaf, why size are they? 1/2 inch fits too loose in the sleeve that came with the lift and 5/8 doesn't fit? [IMG][/IMG]
Jwfinley is offline
post #2 of 12 Old 08-19-2011, 06:39 PM
gojeepin
gojeepin's Avatar
1983 CJ7
There's no shackle pictured.
BTW... I like the springs mounted with the bolt head facing out and the nut on the inboard side.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 12 Old 08-19-2011, 06:51 PM
skizriz
skizriz's Avatar
1978 CJ7
I just replaced my bushings, and the bolts were 9/16.
skizriz is online now
post #4 of 12 Old 08-19-2011, 07:23 PM
gmakra
Your in full droop, put the wheels on it and set it on the ground the shackle where it attaches to the spring should be forward of the center line of the top shackle bolt. the springs will settle after a month or so.
gmakra is offline
post #5 of 12 Old 08-19-2011, 07:36 PM
EthanW
1979 CJ5
I had the same issues with my BDS 4" lift. I had to put all 4's on the ground and flex the heck out of it with no shocks and no sway bar. I put a jack with a bock of wood on each corner and one at a time flexed it until the tire on the opposite side came off the ground. Pictures and thread here:
https://www.jeepforum.com/forum/f8/4-...oblem-1219243/
EthanW is offline
post #6 of 12 Old 08-19-2011, 08:04 PM
John N
1981 CJ8
The bolts for the main (rear) spring eyes are 9/16". They can be hard to find.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #7 of 12 Old 08-19-2011, 10:29 PM
mrmrezg
1982 CJ5
Them are some purty jack stands. Yes, your shackle is pulled back because your axle is pulling your spring down.
mrmrezg is offline
post #8 of 12 Old 08-19-2011, 11:20 PM
yahwhy
1982 CJ7
like gmakra said, and probally should patch the frame up, looking eat up by the shackles
yahwhy is offline
post #9 of 12 Old 08-20-2011, 06:36 AM
EthanW
1979 CJ5
I found them at Lowes.
EthanW is offline
post #10 of 12 Old 08-20-2011, 07:41 AM
trader
1976 CJ5
just saying " howdy", noticed you are from lexington. i am 50 miles to the northeast.
76 cj5, glass body, 360- dui, t150, locked 30 & 20 locked, one piece, 4:10
4 inch susp. lift 1 inch body, 33 swampers, disc front brake,
mile marker winch,on board air, agr steering, full roll cage.
trader is offline
post #11 of 12 Old 08-20-2011, 08:46 PM Thread Starter
Jwfinley
1978 CJ7
What's up trader, where you located?
Yea the frame is getting a face lift this winter, frame and wiring is the winter project.
Also, thanks for the input, good to know that the everything will settle after I drop her off those very pretty stands...
Jwfinley is offline
post #12 of 12 Old 08-20-2011, 09:11 PM
trader
1976 CJ5
i am in fleming co. i drive a semi truck to pick up a load about every week in lex.
trader is offline
