Diff Identification - JeepForum.com
 3Likes
post #1 of 51 Old 07-28-2019, 07:13 PM Thread Starter
Jcminto
Jcminto's Avatar
1977 CJ5
Diff Identification
Good day all, I know there is a bunch of diff identification on this site, just looking for clarification is all, I bought this 77 Cj5 and was told it had Dana 35 axles, but I think I'm looking at a Dana 60 rear
Jcminto is offline
post #2 of 51 Old 07-28-2019, 07:17 PM Thread Starter
Jcminto
Jcminto's Avatar
1977 CJ5
Actually now that I look closer I'm thinking Dana 44 that he has put a vent and drain plug into....
Jcminto is offline
post #3 of 51 Old 07-28-2019, 07:36 PM
jp360cj
1977 CJ7
The D44 and D60 look basically the same except for the size, so they can be tough to differentiate in a picture. But my guess would be D44.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #4 of 51 Old 07-28-2019, 07:54 PM Thread Starter
Jcminto
Jcminto's Avatar
1977 CJ5
thank you, I agree with Dana 44 after I took another look,
I'm having more trouble with the front. There is no tags to be found on this thing. well other than the VIN lol. and the previous owner has swapped things that don't make sense to me. I was researching ignition mods the other day and mine has points, but I thought jeep went away from points after '74? and the carb appears to be a Carter BBD and from an '81 I believe...
Jcminto is offline
post #5 of 51 Old 07-28-2019, 08:15 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
Im thinking 60. https://comancheclub.com/uploads/arc...ff0d2fc154.jpg
The bolt pattern/shape more closely resembles a 60.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
post #6 of 51 Old 07-28-2019, 08:46 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Top left corner, the cover has a inward curve for the bolt on the 60, on the 44 it is still rounded outwards.
Is there any tag or casting numbers on it? A tag held by the cover bolts?
There are numbers stamped into the ring gear. You could always pull the cover and look for that. I found this link for ID with the part numbers on the gears if it is a D44:
https://tomsdifferentials.com/2011ca...Pages89-94.pdf
It's the 18437 in this picture (found online)
Dunno why the picture isn't working.... shows in the preview...
Here is another resource:
https://www.differentials.com/techni...dentification/
Rick
Cutlass327 is offline
post #7 of 51 Old 07-28-2019, 09:41 PM Thread Starter
Jcminto
Jcminto's Avatar
1977 CJ5
there are no marks on the outside at all, or tags, and I want to pull the covers and check the condition of things, kinda wanted to buy the gaskets first. But maybe I will have to pull it and then buy the gasket.
I did however find this on the bottom of the front diff.
Jcminto is offline
post #8 of 51 Old 07-28-2019, 10:12 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
BOM and date stamps are on the front of the tube to the right side of the pumpkin for a Dana (anything is possible, but Dana were reasonably consistent). The tags may be gone, but you could raise the stamp by gently polishing the surface and then use a piece of paper and crayon to lift the numbers. There may also be a model number stamped on to the pumpkin casting at bottom right, just outside the cover.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #9 of 51 Old 07-28-2019, 10:15 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
I would have guessed Dana 30 front, Dana 44 rear.
post #10 of 51 Old 07-28-2019, 10:21 PM Thread Starter
Jcminto
Jcminto's Avatar
1977 CJ5
Originally Posted by BagusJeep View Post
BOM stamps are on the top of the tube to one side of the pumpkin for a Dana.
I ran my hand all along the top of the tubes and couldn't find anything, but I'm going to grab a light and some cleaner and go look again,
Jcminto is offline
post #11 of 51 Old 07-28-2019, 10:25 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
I said top and then changed it to front. Memory is not as good as used to be since I gave up drinking.
post #12 of 51 Old 07-28-2019, 10:30 PM Thread Starter
Jcminto
Jcminto's Avatar
1977 CJ5
I'll go back out......
Jcminto is offline
post #13 of 51 Old 07-28-2019, 10:36 PM Thread Starter
Jcminto
Jcminto's Avatar
1977 CJ5
Nothing on the front either, I switched to Budwiser prohibition brew a while ago.
Jcminto is offline
post #14 of 51 Old 07-29-2019, 04:52 AM
Axhammer
Axhammer's Avatar
Model number is cast into the carrier web. See attached.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #15 of 51 Old 07-29-2019, 06:19 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I'm thinking 60 also based on the shape Cutlass mentioned.
@Cutlass pictures that don't begin with "https" won't post anymore.
Cutlass327 likes this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
