Detroit TrueTrac lube recommendations - JeepForum.com
 6Likes
  • 1 Post By 80cj
  • 1 Post By Chewtoy
  • 2 Post By CSP
  • 2 Post By Axhammer
post #1 of 7 Old 07-28-2021, 12:03 PM Thread Starter
My83andMe
1983 CJ7
Hey all,
I'm slowly making progress on getting my jeep back on the road.
Soon with be changing out the Diff fluids (D30 and AMC20) both with Detroit Truetrac installed.
I have been looking over the requirements... friction additives vs not... its all very confusing.
Can someone please clarify this and give best recommendations as to what I need to put in there. I have no clue what is is there now sadly.
I appreciate you all
Shawn
I thank you and believe me my Jeep definatly thanks you cus otherwise I'd be turning a wrench with out a clue. :)
My83andMe is offline
post #2 of 7 Old 07-28-2021, 01:21 PM
80cj
80cj's Avatar
1980 CJ5
Did a quick web search and this is the first thing that popped up.
https://www.eaton.com/us/en-us/produ...trac-faqs.html
Axhammer likes this.
80cj is online now
post #3 of 7 Old 07-31-2021, 12:19 PM
Chewtoy
1976 CJ5
if these are real Trutracs, the 2 or 4 screw torsion style limited slip, then they don't need additives. Just put your normal gear oil in and go about your happy day :-)
Rondawg80 likes this.
Chewtoy is offline
post #4 of 7 Old 08-01-2021, 08:49 PM
CSP
Trutrac is a non-clutch type of limited slip. No additives required.
There's no harm in using additives in a diff that doesn't need them as well. Many synthetics do not require additives when used in clutch type limited slips and work in any diff.
uptillnow and Rondawg80 like this.
CSP is offline
post #5 of 7 Old 08-01-2021, 11:23 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Make sure you positivity identify it as a tru trac.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is online now
post #6 of 7 Old 08-02-2021, 03:00 AM
Axhammer
Axhammer's Avatar
From Eatons website link posted above. In black and white.
A quality, petroleum-mineral based, GL5 rated 80w-90 gear oil should be used.
Synthetic oils are not recommended for Truetrac applications. While some customers have found that synthetic oils works well in this application, Eaton has not confirmed under test conditions that all synthetic oils are compatible with Detroit Truetrac applications.
Friction modifiers should not be used because they will decrease performance (reduce differential bias).
jeepster4245 and Rondawg80 like this.
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #7 of 7 Old 08-02-2021, 01:40 PM
uptillnow
uptillnow's Avatar
I have used synthetic GL5 with excellent results. Red Line 75/90NS (NS=non slip, no friction modifiers)
https://www.redlineoil.com/Content/f..._PROD_INFO.pdf
This is an interesting article from 2015 about the lube for truetrac.
https://bobistheoilguy.com/forums/th...uetrac.232583/
uptillnow is offline
