Death wobble caused by sway bar? - JeepForum.com
 11Likes
post #1 of 32 Old 09-07-2021, 10:54 AM Thread Starter
86cj7pete622
86cj7pete622's Avatar
Hey guys,
So I took my 86 CJ7 offroading (nothing crazy) for 3-4hrs and when I got back to pavement, I got death wobble within a few miles. I was doing 35-40mph at the time, no bumps/potholes in the road.
I looked underneath and found that my sway bar bushing bracket on the driver side unbolted itself (the bushing bracket that attaches to the frame- picture attached). If this bracket just happen to come off while on pavement, would that have possibly created a jerking jolt to start DW?
My ball joints, beefier drag link, and beefier tie rod are all less than a year old. I drove it again at 60mph and no out of balance 33" tires. I don't see any slop in any of the components. The only obvious thing was that sway bar bracket that came loose.
I had DW about 20yo, but smooth sailing until this weekend.
Thanks.
86cj7pete622 is offline
post #2 of 32 Old 09-07-2021, 11:18 AM
StoneTower
Bolt it back up and see if the problem goes away. It looks in the picture that the sway bar has been pulled back. Did you hit something that bent a spring or something? The sway bar is a spring and if you have it connected properly to one wheel and not the other, the suspension is not going to work properly especially at road speeds.
80cj likes this.
StoneTower is offline
post #3 of 32 Old 09-07-2021, 01:44 PM
stripperguy
It’s unusual for a leaf sprung vehicle to have a death wobble. the lateral stiffness of the suspension usually keeps the critical frequency of that vibration mode above the frequency of the tires. In addition, there is usually enough damping in the leaf to leaf interface to preclude such motions.
Obviously, your situation is not typical, but that doesn’t help you, since it happened.
I would look at any component that allows lateral motion, spring mounts, spring clamps, shackles,
Also see if you’ve lost any wheels weights. Even though you could drive again at higher speeds, if you pass through that critical frequency quickly enough, a marginally stable system may not go unstable, as there is a time function involved as well
Renegade82, Neuner-9R and Wyo like this.
1977 CJ5 is a CJ build ever really done?
2002 TJ gone
2005 TJ also gone
2005 LJ insurance wreck
stripperguy is online now
post #4 of 32 Old 09-07-2021, 01:48 PM
ECJ-7
1976 CJ7
sway bar shouldn't have anything to do with a wobble. You don't need a sway bar except in hard cornering to keep the vehicle level.
OrangeCJ-5 likes this.
ECJ-7 is offline
post #5 of 32 Old 09-07-2021, 02:40 PM
StoneTower
A sway bar was never intended to be attached on one side and not the other. I am sure it being disconnected on one side is not helping the problem.
post #6 of 32 Old 09-07-2021, 04:08 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Look these over
https://www.youtube.com/results?sear...th+wobble+jeep
Some are better than others
Once you neglect it, or it does it intermittently
It's too late!
I complained several times about DW in the van where I used to work.
It was intermittent and hitting a small pothole or a slight uneven spot in the pavement "Could" set it off.
Like everything else you want to show somebody else, it might go days before you hit something just right.
I showed the boss that it was perfectly fine and I was an idiot and my going slow proved that I was just a sniveler after maybe 5 "check this outs!"
I had spread the word, and it got back to him.
While I was performing a task, he stormed over and said this was the last time he was going to test it.
I reckon since he would not let me ride with him this time, The "ONE" person at 60 MPH was all he needed!
Not even out of site, he wobbled a few yards and decided to counter it with by gaining even more yardage sliding the whole driver's side down the road.
That fixed the problem!
I had another van within the week!
------JEEPFELLER
JEEPFELLER is offline
post #7 of 32 Old 09-07-2021, 09:32 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
X2
Barring front end damage, DW is usually caused by a caster issue or loose U bolts.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #8 of 32 Old 09-10-2021, 04:06 AM
ECJ-7
1976 CJ7
Originally Posted by jeepdaddy2000 View Post
X2
I bought a '65 falcon way back with the death wobble and it turned out to be a bad shock and a bald tire. If you hit a bump just right she'd start until you came to a complete stop.
ECJ-7 is offline
post #9 of 32 Old 09-12-2021, 12:51 PM
80cj
80cj's Avatar
1980 CJ5
I drove for a long time with one link on my sway bar disconnected and finally ended up removing it. Problem was that I was getting stuck offroad a lot because the sway bar was seriously limiting articulation. My suspension is firm enough that I feel comfortable driving without the swaybar. Difficult to imagine how the sway bar could affect death wobble. Never made a difference on my Jeep after disconnecting and finally removing it. As was suggested, try reattaching it and see if it takes care of the problem. If it solves the problem, then we all have learned something new.
80cj is online now
post #10 of 32 Old 09-12-2021, 07:15 PM
jeepdaddy2000
1971 CJ5
Apples to oranges. A car's front suspension is completely different than a CJ's.
Chesty Puller
post #11 of 32 Old 09-13-2021, 04:29 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I always heard about the death wobble but never experienced it until I bought a JK and it was all stock.
My sons JK did the same thing. New steering dampener fixed it.
Never had it in my CJ.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #12 of 32 Old 09-13-2021, 07:21 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I've always thought that if you have death wobble at a certain speed, that goes away at different speeds, you have a tire balance problem.
Matt
Matt1981CJ7 is offline
post #13 of 32 Old 09-13-2021, 11:30 AM
Renegade82
Renegade82's Avatar
1982 CJ7
Originally Posted by stripperguy View Post
Itís unusual for a leaf sprung vehicle to have a death wobble. the lateral stiffness of the suspension usually keeps the critical frequency of that vibration mode above the frequency of the tires. In addition, there is usually enough damping in the leaf to leaf interface to preclude such motions.
That's correct as far as everything I've read. Jeeps don't get death wobble. That's more of a Wrangler thing. Jeeps get bump steer, mostly because the drag link and the tie rod are not even close to being parallel. Worn ball joints can also contribute to it.
I've had what is similar to death wobble and it came from having a frozen, or dried out rusted u-joint at the front wheel. I would have never guessed that but I had taken my Jeep to my cousin who was a mechanic. He found it, replaced it, and it was gone.
I suggest putting your front end up on the frame so that your strg. and suspension is loose and unloaded. Then start yanking and pushing on things to see what moves. Use a pry bar under your tires and lift up. Have someone inside cycling the steering back and forth as you watch.
robblue6412 likes this.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #14 of 32 Old 09-13-2021, 02:32 PM
StoneTower
Some CJs do get death wobble. This is an old post from one of our members.
post #15 of 32 Old 09-13-2021, 03:42 PM
Matt1981CJ7
1981 CJ7
This excellent article has a good section on death wobble, which can most certainly affect CJs.
https://www.scribd.com/document/1323...pension-Basics
StoneTower, did the owner of the CJ in that video ever figure out what was causing the death wobble? My money is on a tire balance issue.
Matt
