The Death Machine build - Page 4 - JeepForum.com
post #46 of 78 Old 12-03-2015, 01:00 AM
Dadamsnv
Dadamsnv's Avatar
1977 CJ5
sub'd 8)
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #47 of 78 Old 12-04-2015, 08:55 PM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
Alright guys, so I swapped out the axle today. Everything bolted in fine.
Savemycj is offline
post #48 of 78 Old 12-04-2015, 08:56 PM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
I know there's no axle in that pic, just use your imagination.
Savemycj is offline
post #49 of 78 Old 12-04-2015, 09:02 PM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
Apparently the donor axle had the wrong brake pads on it. I honestly don't see how the previous owner of the axle could've stopped. When I pressed the brakes the cylinders in the rear shot out the Pistons because the shoes were too small to contact the drum. So I swapped all the hardware and drums from the original axle onto the donor and I'll bleed the system in the morning.
Savemycj is offline
post #50 of 78 Old 12-04-2015, 09:03 PM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
And here is the busted original. (At least the pinion seal is good)
Savemycj is offline
post #51 of 78 Old 12-04-2015, 09:07 PM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
The gears inside look fine, there is no obvious damage or scoring I can see. All the teeth are there. Maybe someone here can chime in on this? When I'd let off the clutch the driveshaft would spin and it would let out a grind and not move. Maybe one of the splines have stripped? I'll look closer tomorrow.
Savemycj is offline
post #52 of 78 Old 12-05-2015, 06:44 AM
lovett86
lovett86's Avatar
Maybe something in the spider gears that u can't see, try spinning the pinion by hand or have someone spin one of the wheels for you and look inside to see what's going on, u can always post a video too
its a rusty one
https://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #53 of 78 Old 12-05-2015, 08:24 AM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
I spun it by hand and there is an excessive amount of play in the gears, but I couldn't get it to "grind" by hand. Everything seems to spin ok, but under engine torque something gives.
Savemycj is offline
post #54 of 78 Old 12-05-2015, 08:31 AM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
And on a separate note, here's the donor axle's brake shoes and drum. These shoes are too small, but unfortunately I didn't notice until the test drive last night.
Savemycj is offline
post #55 of 78 Old 12-05-2015, 09:45 AM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
Well I found the culprit.
Savemycj is offline
post #56 of 78 Old 12-05-2015, 11:33 AM
Dadamsnv
Dadamsnv's Avatar
1977 CJ5
Wow! don't reuse that yoke!
Dadamsnv is offline
post #57 of 78 Old 12-05-2015, 03:02 PM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
I guess I should've zoomed out a bit, that's the passenger side axle shaft
Savemycj is offline
post #58 of 78 Old 12-05-2015, 03:13 PM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
The date code stamped onto the ring gear is from 1998. Apparently this axle was rebuilt not too long ago, but I wonder why the splines wore out so fast? The other axle shaft isn't as bad but it was close.
Savemycj is offline
post #59 of 78 Old 12-05-2015, 03:17 PM
lovett86
lovett86's Avatar
It probably saw a lot of abuse
its a rusty one
lovett86 is offline
post #60 of 78 Old 12-05-2015, 04:59 PM Thread Starter
Savemycj
Savemycj's Avatar
1975 CJ5
You're probably right, when I got this jeep it was obviously used as a trail toy, it was't close to street legal and any repairs or upgrades done to it were pretty sketchy. For example, the Reese hitch welded to the front crossmember. (Before being acidentally ripped out by yours truly)
Savemycj is offline
build , cj , cj5 , daily driver , intermediate
