Dana 300 Shift Lever - JeepForum.com
 1Likes
  • 1 Post By John Strenk
post #1 of 9 Old 05-14-2021, 12:32 PM Thread Starter
Charleston82CJ7
1982 CJ7
So I was trying to remove the shift knob so I could replace the transfer case boot. I grabbed the knob with pliers, and this happened. I didn’t turn it THAT hard! Time for a new shift lever...
Charleston82CJ7 is offline
post #2 of 9 Old 05-14-2021, 02:48 PM
John Strenk
John Strenk's Avatar
1976 CJ5
How tight was that locknut?
Any sign of rust that shows it might of been cracked befor?
STJP likes this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #3 of 9 Old 05-14-2021, 04:21 PM Thread Starter
Charleston82CJ7
1982 CJ7
The lock nut is frozen to the stud. I know I didn’t turn it hard enough to snap a 5/16th stud. I think it was broken before...
post #4 of 9 Old 05-16-2021, 06:24 PM
ScroungerLee
Custom home made
I had the same thing when I bought my Jeep. To solve the problem I made my own shift knobs. For the transfer case I made the hole in the knob to fit the Dana 300 lever since the threaded part was gone. In case I have to take it off some day I used a drop of super glue instead of something like JB Weld
Maybe I should make more and sell them if anyone likes them enough
ScroungerLee is offline
post #5 of 9 Old 05-16-2021, 07:50 PM
davcono
davcono's Avatar
Got one. Fully chromed.
davcono is offline
post #6 of 9 Old 05-17-2021, 02:25 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
I did that once. I just left the lever as is, just one more job i have not completed.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #7 of 9 Old 05-17-2021, 03:53 AM
keith460
keith460's Avatar
You don't want to do it that way. ALL shift knobs need to have the locking nut loosened first with a 3/4" wrench turning clockwise looking down from the top.
Use anti-seize compound during reassembly.
Fixed a friends shift lever that broke the same way on his old Triumph sports car by setting lever arm in a Drill Press. Leveled and squared it as best we could and then drilled several step-up holes until we could tap the threads that were needed to make it like it was originally. Used a piece of all thread with permanent thread locker (red) screwed into the tapped hole and installed the original shift knob back on. Could never tell it had broken.
1984 CJ-7 Renegade
keith460 is offline
post #8 of 9 Old 05-17-2021, 02:40 PM
oldschool74cj5
hello
i found a broke one at the junkyard that was the correct one i needed. i fixed it by grinding the top flat, then drilling and tapping the shifter. then i installed a hardened stud into the shifter using some permanent loctite. havent had a problem with it since.
oldschool
oldschool74cj5 is offline
post #9 of 9 Old 05-18-2021, 04:29 AM
John Strenk
1976 CJ5
Originally Posted by oldschool74cj5 View Post
hello
oldschool
Make sure it's the right one. There are more than one lever for the Dana 300 as I found out.
One with SR-4/300 will not fit the stock setup for a T-176/300. Not sure what a T-4/5 setup will have.
