D300 Hard to Shift - JeepForum.com
 6Likes
post #1 of 16 Old 10-22-2021, 02:46 PM Thread Starter
DouggetCJ7
DouggetCJ7's Avatar
1978 CJ7
D300 Hard to Shift
Hi,
My 78 CJ has an 86 drivetrain... so T5, D300, D30, D44.
Everything seems to work fine (axle gears are a bit too high) except the D300 is very hard to shift.
Not that it doesn't mesh into gear... More that the levers seem to take more effort to move than they should.
Also, It's hard to feel the detents.
For example, I have no idea if I'm in 4Hi or 2Hi... Well, not completely accurate... 4Hi is all the way back, but when I push the lever forward, I don't feel any 'clicks' into 2Hi or N.
Where to start? The Jeep is new to me and I'm fixing as I find issues. This isn't a major issue, since it works as is... but I'm worried that it's a symptom of a bigger problem and therefore I want to figure it out before something big goes wrong.
Thanks,
Doug
Mongo228 likes this.
Doug
1978 CJ-7
258 I6 / T5 / D300 / D30 / D44
DouggetCJ7 is offline
post #2 of 16 Old 10-22-2021, 03:32 PM
Fourtrail
1974 CJ6
How are you trying to shift? At a dead stop? Most find it easiest the shift with the trans in neutral while rolling slowly forward. After you have gotten use to how it likes to shift, it will be easy to find what range you want to be in.
kmiller7351 likes this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #3 of 16 Old 10-23-2021, 02:56 AM
Mongo228
Mongo228's Avatar
1980 CJ7
Dude, I feel ya. My 1980 D300 is one of those "move slowly while shifting" deals. If I try at a dead stop, forget it. And the linkage is well lubed with white lithium. So, yeah, give the slow mo shifting a shot ... like 1/2 mph. That seems to be about where mine is happiest.
Dave
Mesa, AZ
"Grinders and Paint Make You The Welder You Ain't!" -- from a t-shirt
Mongo228 is offline
post #4 of 16 Old 10-23-2021, 06:13 AM
keith460
keith460's Avatar
The D300 is neither a shift on stop or shift on the fly, it's somewhere in between but at a much slower speed. I find shifting from 2H-to-4H requires slow speed in gear but no load, like going up a hill. But can shift from 4H-to-2H at just about any speed. Shifting from 4H-to-4L or 2H-to-4L requires coasting in neutral slowly.
Shift pattern is:
4L
N
2H
4H
1984
CJ-7 Renegade
keith460 is online now
post #5 of 16 Old 10-23-2021, 07:40 AM
Rkuehljr
1983 CJ7
The linkage/pins on the D300 can get quite stiff if not exercised regularly as it collects road dust. It should get easier to move the more you use it and you will learn the feel of where 2H is. You can see the linkage is two pins being pulled in and out by the handle with a swinging connecting link. The setup doesn’t provide much “feel”
Sent from my iPad using Tapatalk
Rkuehljr is offline
post #6 of 16 Old 10-23-2021, 08:58 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
They are all difficult to shift, normal. the drivetrain binds the gears in the box, so the forces fight you. On a loose surface gently coasting at low speed it all frees up.
I put mine in Neutral, which you can check, and then slowly build pressure on the lever until it moves. Should be 2H. I have front hubs unlocked. IF your 4WD light works, it will tell you when you go past into 4H.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #7 of 16 Old 10-23-2021, 09:16 AM
John Strenk
John Strenk's Avatar
1976 CJ5
It's really has o be the geometry and interlock pins of that linkage.
Mine was always terrible to shift from high to low but when I went to twin sticks, it shifts just as smooth as anything I ever tried to shift.
I didn't change or lubricate anything on the t-case when I moodified it.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #8 of 16 Old 10-23-2021, 02:16 PM
80cj
80cj's Avatar
1980 CJ5
Never had any problems with mine. If it won't go in, I put the trans in gear and let the clutch out slowly with the engine idling while applyng moderate pressure on the transfer case shifter. Always works. Sometimes the clutch sleeves aren't aligned with the corresponding splines and all it takes is a little bit of rotation to get things lined up.
80cj is offline
post #9 of 16 Old 10-26-2021, 09:53 AM Thread Starter
DouggetCJ7
DouggetCJ7's Avatar
1978 CJ7
My 4WD light doesn't work... part of the problem. Where is the switch for that?
Doug
1978 CJ-7
post #10 of 16 Old 10-26-2021, 11:06 AM
John Strenk
1976 CJ5
Well looking at your signature, it looks like you have a dana 300 in the 78 but they never came with a dana 300 originally. So maybe you don't have the wire running to it in your harness.
The 'Emergency Drive" light on the 78 speedometer was for the automatic transmission that came out those years.
The Dana 300 does have a switch on it. It's right on top where the shift levers are located.
You will have to get creative to wire that switch to the light in the speedo but it can be done.
Look for a wire coming out of the #56 Position in your bulkhead connector and connect that wire to the switch on the Dana 300
The 78 connector is almost same as the 79.
Touch the wire to ground to see if the light lights up to be sure you have the correct one.
post #11 of 16 Old 10-26-2021, 01:38 PM
basod
I had difficulty shifting mine into 4low. Finally decided to rebuild it a couple years ago during a clutch replacement.
With the shift rail plate not installed in a vise I could still not move the lever into 4 low.
Removed the detents and noted one of the springs slightly longer(nearly un-noticable) swapped them and it shifts smooth now, but firm enough to not pop out of gear
John Strenk likes this.
basod is offline
post #12 of 16 Old 10-26-2021, 09:13 PM
jimmyd85
1980 CJ7
Twin sticked mine to try to get away from the problem of tough shifting the transfer case. Now it is really easy to shift but now the rear axle will slip from 4L to neutral when going down hill with your foot off the gas. Got pretty hairy one time on a steep, icy hill. Have to bungy cord the handle all the way forward to keep it from slipping out. Beware trading one problem for another.
jimmyd85 is offline
post #13 of 16 Old 10-27-2021, 09:45 AM
Matt80cj
1980 CJ7
I have the same thing going on. The twin stick is awesome but does jump out of rear low once ina while. It did this before I twin sticker it too coasting down hill. At least now the front stays in gear. Had it surprise me many times on a trail when I get stuck with only front wheel drive.
Sent from my iPhone using Tapatalk
Matt80cj is offline
post #14 of 16 Old 10-27-2021, 10:37 AM
HuntinDog
1979 CJ5
I like this thread...
In my CJ5 I can put it into 4L just fine, but have to just about bend the shifter to get it back out.
Feathering the clutch in and out, rocking back and forth and slow speed roll don't seem to make much difference.
I'll try all the suggestions here, but might have to go to twin stick.
HuntinDog is offline
post #15 of 16 Old 10-27-2021, 12:11 PM
bob4703
1974 CJ5
I always thought that transfer cases were hard to shift just to make it hard to accidentally put it in the wrong gear. I have a Dana 20 and the shift pattern is 180* out from the 300. I constantly remind folks that the knob isn't a foot rest
I never can shift into 2 Hi without going to 4 Hi first. Don't have a 4WD light either so I usually crawl under and turn the front drive shaft by hand just to make sure. A periodic shot of grease to the fitting on the linkage helps to, but to get a good shot I have to remove the skid plate. One of these days I'll remember to put it back.
Paved roads are prime examples of government over spending!
bob4703 is offline
