Custom Sport Cage Cost... - JeepForum.com
post #1 of 16 Old 12-04-2006, 09:06 PM Thread Starter
Key
I found a guy locally that will custom bend, weld, and install a custom cage anyway I want it for $800. My question is, if I purchased a kit from somewhere like Ten offroad or ORFab, I know the bends will be correct and somewhat cheaper. Should I go with custom or some kit?
Do you think $800 is worth custom?
Key is offline
post #2 of 16 Old 12-04-2006, 09:19 PM
jeepskate
Depends upon exactly what you're getting and what material is being used. Keep in mind that after you buy a pre-fab kit, you still need to have it shipped, fitted, and welded, so factor that into your comparison.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,4.5" RE XD,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: 360,T-999,D300,D30/A20,1-piece shafts,rear discs,33" Fun Country's.
jeepskate is offline
post #3 of 16 Old 12-04-2006, 09:27 PM Thread Starter
Key
Sorry, the material would help..
Up to 2" 120 DOM. 6 point. and tie into frame.
Key is offline
post #4 of 16 Old 12-05-2006, 07:09 AM
Mud Machine
Mud Machine's Avatar
Is the cage for the front or front/rear pasangers?
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS/6.0, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #5 of 16 Old 12-05-2006, 08:15 AM Thread Starter
Key
Cage will be to protect both front and rear.
Key is offline
post #6 of 16 Old 12-05-2006, 08:27 AM
Mud Machine
Sounds like a great deal to me!!!
After-market cage will probably end up costing you a lot more than that by the time you get it completed and installed.
I say go for it. Just make sure to look at some of his other work to be sure you are getting the quality you want.
Note: You should consider paying a little extra and mounting your seats to the cage. Just a thought.
post #7 of 16 Old 12-05-2006, 09:46 AM
ronprice
ronprice's Avatar
Sounds Good
. With the steel prices and cost af a good welders time haveing costom built for that is what I would have done. But I bought a full cage with seat brackets welded to it on e-bay parts a month ago for $60.oo.
ronprice is offline
post #8 of 16 Old 12-05-2006, 12:31 PM
85xj350
Guest
The price is good the last cage that i did was around that much it was a full rally cage in a subaru. The good thing about a custom cage is that you can have it biult the way you want.
85xj350 is offline
post #9 of 16 Old 12-05-2006, 12:33 PM
CCOR
Vendor
$800 is a good deal. I would make sure and look at some other cages this guy has done just to see the quality of work. Ask if the $800 includes any gusseting or tying into the frame if you want that.
Classic City Off Road (CCOR)
Email:
Shop: (706-559-9609)
CCOR is offline
post #10 of 16 Old 12-05-2006, 02:08 PM
jakemary
1977 CJ7
if he is a good welder that would a good deal. a pipe bender goes for around 1,000 and a welder goes for around 1,000 .
jakemary is offline
post #11 of 16 Old 12-05-2006, 08:12 PM
ronprice
ronprice's Avatar
http://http://cgi.ebay.com/ebaymotor...QQcmdZViewItemThis may go cheep!!
Family of 5<Myself and 4 girls. Out numbered and dont care that I leave the seat UP.
-OIIIIIO-
ronprice is offline
post #12 of 16 Old 12-05-2006, 09:18 PM
No_Bs
1977 CJ5
Originally Posted by ronprice
That's really nice, I've seen it in person. It's been sitting up at Paragon for a few months now.
No_Bs is offline
post #13 of 16 Old 12-07-2006, 04:30 PM
ronprice
ronprice's Avatar
If it was closer I would bid myself. If it go's cheep enough I may still. It would only cost an extra 100 or 2 to drive and get it
-OIIIIIO-
ronprice is offline
post #14 of 16 Old 12-07-2006, 06:32 PM
GPER
1979 CJ7
For 800 bucks you can buy a good welder then get a cage kit and do it yourself. Yes it will cost you more foir the cage kit, but when you make your rocker guards for nothing you are ahead.
GPER is offline
post #15 of 16 Old 12-07-2006, 09:30 PM
jeepskate
A cage is not the place to cut your teeth with welding. Not a bad idea to go that route (buying a welder & learning to weld) if you have plans for other stuff, but start with scrap metal and things your life doesn't depend on like rocker guards.
Does anyone know where you can get custom width and length cage padding? HHICJ7 Jeep CJ Forum 3 12-04-2009 05:31 PM
Recommend someone who knows the 84 CJ7 layout who can build a custom cage? HHICJ7 Jeep CJ Forum 2 11-13-2009 04:03 PM
Or-Fab Sport Cage from CJ5 fit CJ7? connor014 Jeep CJ Forum 2 09-27-2008 10:19 PM
custom roll cage CJ DeathTrap Jeep CJ Forum 4 01-21-2008 06:38 PM
77 cj7 bolt in sport cage?? cwbrg Jeep CJ Forum 4 08-24-2005 09:45 AM
