Custom spare tire and jerry can mount - JeepForum.com
 3Likes
  • 2 Post By BadBradWilson
  • 1 Post By jurgen24
post #1 of 9 Old 07-19-2021, 01:17 PM Thread Starter
BadBradWilson
BadBradWilson's Avatar
1971 CJ5
Just wanted to show some pics of the most recent project on my '71 CJ5. Needed a spare tire mount, and I wanted it to swing out so I could still get at the tail gate. My fuel gauge doesn't work, so I thought rather than fix it, I'll just throw a jerry can on the back too. Here's what it looked like before: inkedimg_4406a.jpg
So I kind of held my spare up, measured some things, and built a triangle frame out of 1 1/2" x 3" steel. I built the hinge from a thick pipe and rod that fit together pretty closely, and the pin (on the right side) out of the same material. Strapped the whole thing on and welded my hinge and pin assembly. img_4509a.jpg
I bought the wheel studs and lug nuts without a plan. I ended up cutting a circular piece of steel , drilling holes, and welding them in place. Worked okay, there is probably a better way to do that. img_4519a.jpg
Started building the jerry can holder by tracing the can and cutting it out of 1/4" plate. Then bent some thin strap around it, and made sides and a retainer on top. img_4649a.jpg
Built a special bolt out of all-thread, and ended up welding on some thumb screw tabs (not in this photo) so I don't need a tool to remove it. img_4951a.jpg
The bottom just has my mount, which raised it to the same bottom height as the spare tire, and I cut holes to save weight and drain water. img_4953a.jpg
Anyway, I thought it was a cool project, and didn't find very many examples of DIYers that I liked. Here's the finished deal. img_5520a.jpg
Anybody else build a custom spare mount?
Rondawg80 and Nor Cal CJ5 like this.
BadBradWilson is offline
post #2 of 9 Old 07-19-2021, 04:31 PM
jurgen24
Here is my attempt a while back. Has removable receiver hitch adapter, so I can mount optional rack for longer trips.
https://photos.app.goo.gl/7DL4PJZJ89juj9ko2
Sent from my iPhone using Tapatalk
Nor Cal CJ5 likes this.
jurgen24 is offline
post #3 of 9 Old 07-19-2021, 07:10 PM
Axhammer
Axhammer's Avatar
Looks good to me, and building it yourself is the way to go, if you can handle that kind of fab work. I like having access to my tailgate, so building a swing style spare tire rack will be in my future one day. I can envision your design with minor changes looking good on the back of a CJ-7.
Now you need new “71” numbers in the swing-out arm.
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #4 of 9 Old 07-20-2021, 03:02 PM Thread Starter
BadBradWilson
1971 CJ5
Jurgen24- Wow, that's doctorate level. Very cool!
post #5 of 9 Old 07-20-2021, 08:28 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
I put a swing gate on both of my Jeeps, they are sorta similar
I reckon I'm prouder on the one on my '46
Also see my pics in "post 3" in this link
https://www.jeepforum.com/forum/f8/s...mpers-4420421/
----JEEPFELLER
JEEPFELLER is offline
post #6 of 9 Old 07-20-2021, 08:48 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Looks very solid, do you have an approximate weight?
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #7 of 9 Old 07-21-2021, 12:35 AM
80cj
80cj's Avatar
1980 CJ5
Nice 71! Is it a 4 cylinder or V-6?
80cj is offline
post #8 of 9 Old 07-21-2021, 08:24 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Weight?
Rack alone maybe close to 50 lbs???
Willy kinda has the square tubing close together, and it's a little narrower than "Mr. Jeeps" and is better self supporting
If I go back to make it better, I'll weld a angled strap of sorts (like a turn buckle) high on the hinge side and low towards the middle to keep the little bit of sag that it has out of it when it's opened.
----JEEPFELLER
post #9 of 9 Old 07-22-2021, 12:08 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Yes, it is one of the design issues to get a rigid and robust frame without adding weight. When you then put on a large off road tyre the forces off roading can be significant.
Unfortunately my engineers would tell on me if I asked them to evaluate a tyre mount, all our machines have tracks!
