Custom axle measurements - JeepForum.com
post #1 of 7 Old 07-05-2020, 09:48 PM Thread Starter
MattC71
At the point to have custom axles for my 1978 CJ5 build. I am going 9" rear and Chevy Dana 44 front. I am narrowing them to wide track width. Since I don't have the original axles, jeep came as a bunch of parts, I need some measurements to cut the axles down. The trails near me can be narrow so I don't want to go full width.
Rear axle - Is the rear diff centered or offset? Width should be 55" WMS to WMS
Front axle - Since the drivers spring perch is cast into the housing, how much is needed to cut off each side to fit the width? Width should be 56" WMS to WMS
I am having a shop cut and narrow the axles, trying to get some measurements for him. I can weld brackets and such, just don't want to take a chance on the axle tubes.
Thanks in advance for the help.
MattC71 is offline
post #2 of 7 Old 07-05-2020, 10:18 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
You had a Dana 20 transfer case with centred rear output and passenger side front output.
Do you need to centre the rear axle pumpkin? I say yes because it is a Cj5 and the rear driveshaft is very short. On a CJ7 you can get away with it not being centred, my early landcruiser axles on Puthijeep being like that.
As to how much to cut, I suggest you measure where your springs are. I do not have a note of the spacing.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 7 Old 07-06-2020, 09:23 AM
Axhammer
Axhammer's Avatar
Are you doing a drivers or passenger side drop for the front?
If you want a passenger side drop you can start with a mid seventies Waggoner front Dana 44. They are about 61 WMS width. You can cut the long side about 4 to get the 27.5 spring perch needed. You will end up with about 57 WMS width. This project can be done on the tailgate of a pickup truck, so no special tools are needed. As long as you have a welder, or you could do the work and take it to a professional welder. Check out the link below.
http://www.jeeptech.com/convaxle/sjd44front.html
I have a Ford 9 from an early Bronco at 58 WMS width. Im having 1978 Ford Bronco Hi pinion 44 retubbed For a passenger drop and 59-60 WMS width for my CJ-7. Its getting a YJ leaf SOA conversion and stretch, Im looking for another 5 of wheelbase.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is online now
post #4 of 7 Old 07-06-2020, 09:54 AM
jurgen24
If you are changing your bolt pattern, I would suggest assembling your axles before you decide to make any cuts. For example for a generic D44, you could use Chevy small spindle, F150 rotors and hubs for 5 on 5.5.
After assembly you can locate the other spring perch from the cast location and can easily work out how much to cut from each side to arrive at your WMS. In this way it is also easy to know the length of custom axle shafts as its the current length - cut off per side.
One thing to decide is if you want the front drive shaft to spin at high speed. If so you may need to reprofile your perch so pumpkin points at transfer case and the run double cardan. I mention this, as the inner C would need more turning to maintain 7 deg caster.
Sent from my iPhone using Tapatalk
jurgen24 is offline
post #5 of 7 Old 07-06-2020, 10:24 AM
whodatschrome
This doesn't answer your question, but it's other things to think about...
If bigger axles are going to be installed, i'm guessing bigger tires are going to be installed as well? If so, going with a wider front axle will give the front tires the ability to turn lock to lock without them rubbing against the frame. Just another thing to think about.
And x2 on what Jurgen said about changing the perch on the front pumpkin and getting the correct caster angle for the amount of lift you're after. Depending on driveline angles and about of lift you're after, both inner C's might need to be cut and turned.
whodatschrome is offline
post #6 of 7 Old 07-06-2020, 11:46 AM Thread Starter
MattC71
Guys,
Thanks for all the input. I am planning a passenger side drop and 5x5.5 bolt pattern with F150 hubs. I was considering going with EB width at 58". The axle shafts would be more common size. I may go that route to give a better turn radius. I want to run YJ springs SOA and 35" tires. Does anyone know the distance from the inner C to WMS? The axle are disassembled so I can't measure.
MattC71 is offline
post #7 of 7 Old 07-06-2020, 01:14 PM
jurgen24
Originally Posted by MattC71 View Post
Guys,
I have a note in my log book that center of ball joint to WMS is 7.5, but dont quote me on that
I did a whole bunch of calculations/searches but for some reason I could not find stock axle shafts that got me to my target WMS of around 58-3/4. Also I found that custom chromoly axles from Dutchman, were not much more $ than chromoly of stock length.
jurgen24 is offline
