Cruisecontrol electrical setup Cj-7 - JeepForum.com
post #1 of 4 Old 11-20-2010, 05:05 AM Thread Starter
jorns
Hi.
I have 86 Cj7. With 258 engine and a TF-999 automatic. The viechle is suplied with factory cruise control.
I bought this Jeep in parts (actually everything where wraped in boxes) and have the last year build it together. But i have some questions about the cruisecontrol. As you see in the attached picture there are several wires to connect, and I have som questions about them and also just needs someone to confirm that my connection will be correct.
1) Red wire should be conected to the steeringcollumn socket. The first cable (white) in the big plug.
Red/White, I have no idea, but i am thinking that this should be powersupply after ignition. Correct?
The red/white has a fuse (glas) as the arrow points at.
2)On the old fuse panel i have a socket with "cruise" texted. But on the Painless wiring system there arent any. Could i just connect it to in example "Acc"? (Acc=accesories?)
But will it be on a protected circuit? Like a fuse that protect it against shorting?
3)This one is ok, i have the same plug in the other end from the engine room. No idea what it is though)
4)Same plug come from the steering column. Guess it is the cruise control arm.
5)I This one i think comes from the servo on the speedomether cable.
thanks in advance. My english is not good, but, i hopeyou understand it.
Jorn
1986 Jeep Cj7, 258CID, Dana300/30/44, Automatic, frame off 2010/11.
jorns is offline
post #2 of 4 Old 11-21-2010, 10:39 AM Thread Starter
jorns
*Bump*
jorns is offline
post #3 of 4 Old 11-21-2010, 01:30 PM
keith460
keith460's Avatar
This print should help.
1) Plug goes to "additional" brake light switch. (labeled C123 on print)
2) Power for the Cruise Command Regulator. Plugs into the fuse panel. (labeled C203 on print)
3) Plug for Cruise Command Servo located in the engine compartment. (labeled C208 on print)
4) Plug for Cruise Command Switch at steering column (labeled C205 on print)
5) Plug for Speed Sensor (encoder) on speedometer cable. (labeled C206 on print)
1984 CJ-7 Renegade
keith460 is offline
post #4 of 4 Old 11-21-2010, 02:45 PM Thread Starter
jorns
Thanks a lot.
jorns is offline
Hydroboost setup lemahoney08 Jeep CJ Forum 5 08-06-2010 12:39 PM
PCV Setup corrtek Jeep CJ Forum 4 06-04-2010 12:59 AM
What do you think the setup on the CJ is? hizza Jeep CJ Forum 16 03-06-2009 12:09 PM
how much lift do i have with the soa setup?? redcj576 Jeep CJ Forum 4 11-26-2008 06:23 PM
85' CJ7 setup?'s skazaphava Jeep CJ Forum 0 01-14-2008 01:06 PM
