Couldnt get in gear . Had to adjust linkage - JeepForum.com
 9Likes
post #1 of 43 Old 07-04-2020, 03:18 PM Thread Starter
agear
So the otther day I was driving to the parts store and noticed it was hard to get in gear.so i adjusted the clutch linkage and got home. I'm just wondering why this happened ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 43 Old 07-04-2020, 03:43 PM
LumpyGrits
You should have 1 1/4-1 1/2" pedal free travel.
Ck linkage for wear-ASAP
Ck tranny mount for movement.
pedal2themetai likes this.
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 43 Old 07-07-2020, 03:34 PM Thread Starter
agear
My tranny mount bolts were tight and my linkage is in good shape. I have the kit with the heim joints. And my freeplay is good but going into first doesnt feel right
agear is offline
post #4 of 43 Old 07-07-2020, 03:43 PM
pedal2themetai
1956 CJ5
HI try taking away some of the free play up top so you engage more clutch and see if that helps.. also check the fluid level might be low??
good luck
tim
pedal2themetai is offline
post #5 of 43 Old 07-07-2020, 04:30 PM
oldschool74cj5
hello
the actual free play you want on a cj with a 258 or the 304 is 1 to 1-1/4 of a inch. i always run mine at the 1 inch mark. if you have to much free play on the top that means that you are not pushing the pressure plate enough to release the clutch disc completely and the disc will drag and not want to shift. at one inch and a fairly new clutch i have about a 1 inch at the bottom. letting the pedal up about a inch it starts to grab the disc between the pressure plate and the flywheel.
check all of your clutch linkage for wear because with alot of wear can give you issues. on jeeps when i do a clutch i also always replace the linkage assy parts also.
oldschool
oldschool74cj5 is online now
post #6 of 43 Old 07-07-2020, 05:49 PM
LumpyGrits
Note, as the clutch friction plate wears.
Pedal freeplay is reduced.
post #7 of 43 Old 07-07-2020, 06:41 PM
oldschool74cj5
hello
cj's ran about 1 inch of free play and the FSJ ran just over 1/2 inch in the early 80's. IAW the FSM. my rule has always been i want as minimum amount of free play in my pedals. from the time i ran bugs,civics and jeeps ive always adjusted them all the same way with a small amount of free play. as long as i had a little bit of play in the fork and throw out bearing it was good. that always gave me a great feeling balanced clutch that i have enjoyed. that is part of the reason i have always loved having a mechanical or cable linkage system. very adjustable and it passes on the feel of the spring in the pressure plate. you can feel the change of tension as the clutch is engaging.
oldschool
post #8 of 43 Old 07-08-2020, 04:11 PM Thread Starter
agear
Thank you guys. I have the rod links heim joint linkage set up. My fluid level was good but it still isn't smooth going into first. I'll see if theres any slack in the rid at the pedal
agear is offline
post #9 of 43 Old 07-08-2020, 07:20 PM
LumpyGrits
What model transmission is this?
post #10 of 43 Old 07-08-2020, 08:14 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Iíve seen were the linkage punches thought the release arm unexpectedly.
Check that also.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #11 of 43 Old 07-08-2020, 08:28 PM Thread Starter
agear
Lumpy , I have the T5.
John, if you mean by release arm , bellcrank, my bellcrank isn't worn its good.
agear is offline
post #12 of 43 Old 07-08-2020, 09:44 PM
John Strenk
1976 CJ5
Not the bell crank, The release arm.
I also had a heim joint linkage and oneday I suddenly had about 3" of freeplay and when I went underneath, I saw the short linkage arm had punched through the end of the release arm.
It was like, wow, never thought that could happen.
post #13 of 43 Old 07-09-2020, 05:20 AM
bob4703
1974 CJ5
You mean like this John?
Paved roads are prime examples of government over spending!
bob4703 is offline
post #14 of 43 Old 07-09-2020, 05:43 AM
John Strenk
1976 CJ5
Exactly !!!
post #15 of 43 Old 07-09-2020, 06:20 AM
keith460
keith460's Avatar
That could be caused by pedal travel being to long. Pushing the pedal all the way in, as usual, but links are at their ends and throw out bearing has no more room to move. Pedal pressure eventually pushes the adjusting rod through the lever arm. Proper pedal freeplay adjustment is what will eliminate that.
1984 CJ-7 Renegade
keith460 is offline
