Is this the correct placement for the Fuel Filter - JeepForum.com
post #1 of 3 Old 04-22-2019, 08:26 AM Thread Starter
aillon
aillon's Avatar
Hi Everyone, (Matt in particular),
Is this the correct placement for the fuel filter? I am trying to move it away from the manifold and make it parallel. At its closest point the line is 4 inches away from the manifold (not as close as it looks in the pic)
If not, if you have a picture on how it should look I would very much appreciate it. With the line going into the Carb being low it is difficult to get it much higher and make it parallel.
Thank you.
aillon is offline
post #2 of 3 Old 04-22-2019, 08:39 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I might make the inlet hose a lot shorter and rotate the fuel filter so the return port is at the 12:00 position.
John Strenk is offline
post #3 of 3 Old 04-22-2019, 09:27 AM Thread Starter
aillon
aillon's Avatar
I think i have this right now, what do you think? I used a longer hose to the return and a shorter hose inbound to the fuel filter. Its up much higher now too.
aillon is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
Adjustable FPR and cross flow fuel rail on the cheap Cobra Jeep YJ Wrangler Technical Forum 6 12-30-2018 07:22 AM
Almost stall on stops when engine is hot. High LTFT dynamiccast WJ Grand Cherokee Forum 3 12-07-2018 12:11 PM
Rough idle and hard start Nevsky XJ Cherokee Technical Forum 5 08-31-2018 07:40 PM
Anyone have a CRD fuel filter leak before? gcjeepjames WK Grand Cherokee & XK Commander Forum 10 07-08-2018 07:27 PM
