Cooling Issue With Electric Fans - JeepForum.com
 3Likes
post #1 of 27 Old 06-16-2018, 06:04 AM Thread Starter
SteveOCJ5
1981 CJ5
I recently put in a fresh SBC 350 along with a Champion 3 row aluminum radiator. Ran the mechanical fan for a month and it was always a cool 190 degrees. Well yesterday I installed a dual 12" electric system (puller fans) with shroud and I noticed the temp climb to around 230 before I shut her off (the fans were on). I don't like that at all.. Each fan show to pull 870 cfm for a total of 1940 cfm which I'm not sure is enough for my set up.
Anyone have any insight as to what I should do.. Or should I just stick to my good ol reliable mechanical fan?
Thanks!
SteveOCJ5 is offline
post #2 of 27 Old 06-16-2018, 06:34 AM
Dryseals
1980 CJ7
Was this moving or stopped?
Post a picture of the setup, something tells me its actually blocking flow.
Dryseals is offline
post #3 of 27 Old 06-16-2018, 06:41 AM Thread Starter
SteveOCJ5
1981 CJ5
Here's a couple pics of the setup. Temps got up when I was driving around.
Sent from my XT1585 using Tapatalk
post #4 of 27 Old 06-16-2018, 07:45 AM
Dryseals
1980 CJ7
I'm sure you have checked for fan rotation, but I do have to ask.
Opps sorry, noticed you had said pullers...
Dryseals is offline
post #5 of 27 Old 06-16-2018, 07:47 AM Thread Starter
SteveOCJ5
1981 CJ5
Absolutely. Fans were both running.
post #6 of 27 Old 06-16-2018, 07:57 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I have to ask, why did you choose to go electric when the mechanical was working perfectly?
Matt
Matt1981CJ7 is offline
post #7 of 27 Old 06-16-2018, 07:59 AM Thread Starter
SteveOCJ5
1981 CJ5
Good question. HP increase, efficiency, etc. Plus I had it laying around for awhile so decided to give it a shot...
post #8 of 27 Old 06-16-2018, 08:15 AM
Matt1981CJ7
1981 CJ7
If it ain't broke.....
I must say, that's one good looking engine compartment.
Sorry I couldn't be more help. Good luck, and let us know what you figure out.
Matt
post #9 of 27 Old 06-16-2018, 08:16 AM Thread Starter
SteveOCJ5
1981 CJ5
Thanks and I know. I was saying the same thing when I saw the temp gauge start climbing.. lol.
post #10 of 27 Old 06-16-2018, 09:44 AM
Chrisinchwk
1982 CJ7
I had dual 10inch on my 360 and always battled heat. New rad, flush, test at replace etc. I then put a co tour fan in mine a d it worked a lot better. Lately I have wired it so the low speed stays on all the time and it is working really well. Ever had the option of going mechanical.
Chris
Chrisinchwk is offline
post #11 of 27 Old 06-16-2018, 10:36 AM
turbogus
1978 CJ5
X2 I've had great luck with my Contour/Mystique fan setup and it's been working great on my 360 for two years now. I did some other cooling mods but that had the greatest impact.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #12 of 27 Old 06-16-2018, 11:29 AM Thread Starter
SteveOCJ5
1981 CJ5
Upon further review, I put back on my mechanical fan and the gauge still reads high. So now I think it might be my temp gauge.. In the electric fan kit they included a new sending unit. So I removed the original one that came with my gauge and did this (see pic). Appears now to be reading high. What else could I have done since now I have 2 wires that need to be hooked to my sending unit?
post #13 of 27 Old 06-16-2018, 11:40 AM Thread Starter
SteveOCJ5
1981 CJ5
Here's the piece I cut off of the sending unit that came with the gauge..
post #14 of 27 Old 06-16-2018, 11:42 AM
Matt1981CJ7
1981 CJ7
I'd probably try using the original temp sender with both wires attached, and see if the gauge reads accurately and the fans still work properly.
Matt
post #15 of 27 Old 06-16-2018, 11:45 AM Thread Starter
SteveOCJ5
1981 CJ5
The problem I had with that was the original (aftermarket) sending unit did not have a place to mount another wire. The wire went all the way down inside the brass part which screwed into the engine block.
